offset pull disc
   / offset pull disc #1
troweller
Bronze Member
Kubota 3010, Farmall Cub
I am looking around for a used offset pull disc for a 30 hp 4wd tractor. Is a 6 footer too big? I found 5 footer for $600.
A friend got a 6 footer for $200
   / offset pull disc #2
If I remember correctly you need about 9hp poer foot. Not sure they build a 3 footer. /forums/images/graemlins/laugh.gif
   / offset pull disc #3
What is an offset pull disc? Does anyone have pictures? Thanks /forums/images/graemlins/confused.gif
   / offset pull disc #4
No pic, but it's a heavy, agressive, primary tillage tool. Usually a transport type disc with wheels on cylinders and gangs arranged in the shape of half an "X" (or like this>).
   / offset pull disc #6
This is a used 6 ft "Case" offset wheel disc that maybe will show the basic concept. --Ken Sweet
   / offset pull disc #7
find a picture either of your own or something from tbn pages or internet of this offset pull disc and attach or link to it so people aren't confused about what you are talking about.
I am sure you mean a double offset disc made of angle iron frame and 16 or 20 inch disc whose axles in the form of an "x". I am sure your tractor can pull this described disc.
   / offset pull disc #8
Milkman has it right and sweettractors has the picture. don't know if that is what you really want. Also I am not sure one was made for that small of a tractor. The double offset tandem disk is the most common. I have one for my 18.5 horse Satoh. The gangs are more of an x shape.
   / offset pull disc #9
Hello Troweller,
Welcome to TBN.
The offest disk is typically configured like this --\:/
(the colon is the wheels) /forums/images/graemlins/wink.gif. However, I guess you could assemble one in reverse and make it a right-hand disk. /forums/images/graemlins/confused.gif You may be able tho find one older model that you'll be able to pull with 30HP. The trend in today's disks seem to be ever larger discs [the circular blade] and larger disks [the implement], and heavier frames for better penetration. They are a great tool for tillage, you always need to turn left or it can climb the tire. We used to use it to disk under the citrus trees. They can be adjusted to follow way to the right of the tractor so they can run under the trees a couple of feet.
For more information, do a google search for offset disk.
I would pick up the disk for $600; sounds like a deal. You could always resell it if you decide you made a mistake. Make sure the bearings are good.
Here is a link for some small disks:
<font color="green">Burch Manufacturing</font>
phil
   / offset pull disc #10
Hello oliver28472,
I used to see 4' to 6' disks being pulled by a Ford 8N with no trouble other than some wheel slip. As I said in my previous post, you just need to shop around to find an <font color="blue">older</font> disk. They're out there if you can find them.
phil
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A51692)
2007 Ford E-450...
2012 KOMATSU GD655-5 (A52472)
2012 KOMATSU...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2015 Dodge 5500 4X4 Bucket Truck (A52748)
2015 Dodge 5500...
1973 CATERPILLAR 988 LOADER (A52576)
1973 CATERPILLAR...
Fuel Tank (A51573)
Fuel Tank (A51573)
