Grading OH, And how big of a box blade
   / OH, And how big of a box blade #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
I am thinking this 1850 can handle a 72" box easily. Anyone have any comments on that? PT says only 60 but after seeing the HP to weight issue, a 72" would make sense...
   / OH, And how big of a box blade #2
They don't have the low end torque of a conventional tractor. Just my opinion.
   / OH, And how big of a box blade #3
The 6 footer I have on my 1845 has proven to be just the right size. You should be able to pull a 7 footer just fine with an 1850.
With a box blade I've found that heavy is good and I seem to recall that the PT box blades are a little on the light side. I bought a Bush Hog SBX720 ($549.00 at the time) for my 1845 that has worked out well except that at 550 pounds it's a bit light for ripping my hardpacked gravel driveways and for ripping up hardpan. I tossed an old 200 pound lumber wagon axle on top and that helps a lot but it could still use a bit more weight for ripping. For grading it's plenty heavy enough.
Sedgewood
Thanks Sedgewood.
I will look around to find a beefy blade. My only concern is pushing it and making sure the supports are strong enough... I know for the most part it will be in pull mode. Initially I have a 3pt adaper with a modification on it that will allow a tilt.... Lets see if that pays off handsomely or was a big waste of time...
   / OH, And how big of a box blade #5
This is what I'm going to do. I already have a 3pt hitch adaptor, then the BB can go on either the PT or John Deere.
2011 Kubota L3200 (A50120)
2011 Kubota L3200...
2014 Kubota RTV-X900 4x4 Utility Cart (A50322)
2014 Kubota...
43011 (A51691)
43011 (A51691)
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A52748)
Neckover GL24-2-7K...
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
