Grading OH, And how big of a box blade
   / OH, And how big of a box blade #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
I am thinking this 1850 can handle a 72" box easily. Anyone have any comments on that? PT says only 60 but after seeing the HP to weight issue, a 72" would make sense...
   / OH, And how big of a box blade #2
They don't have the low end torque of a conventional tractor. Just my opinion.
   / OH, And how big of a box blade #3
The 6 footer I have on my 1845 has proven to be just the right size. You should be able to pull a 7 footer just fine with an 1850.
With a box blade I've found that heavy is good and I seem to recall that the PT box blades are a little on the light side. I bought a Bush Hog SBX720 ($549.00 at the time) for my 1845 that has worked out well except that at 550 pounds it's a bit light for ripping my hardpacked gravel driveways and for ripping up hardpan. I tossed an old 200 pound lumber wagon axle on top and that helps a lot but it could still use a bit more weight for ripping. For grading it's plenty heavy enough.
Sedgewood
Thanks Sedgewood.
I will look around to find a beefy blade. My only concern is pushing it and making sure the supports are strong enough... I know for the most part it will be in pull mode. Initially I have a 3pt adaper with a modification on it that will allow a tilt.... Lets see if that pays off handsomely or was a big waste of time...
   / OH, And how big of a box blade #5
This is what I'm going to do. I already have a 3pt hitch adaptor, then the BB can go on either the PT or John Deere.
2005 CATERPILLAR 740 - 6X6 OFF ROAD WATER TRUCK (A52706)
2005 CATERPILLAR...
2024 Kubota KX080-4 Midi Excavator (RIDE AND DRIVE) (A50775)
2024 Kubota...
30007 (A53424)
30007 (A53424)
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
UNUSED FUTURE HWG72 - 72" HYD WOOD GRABBER (A54757)
UNUSED FUTURE...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
