OIL BATH FILTER Conversion.....
   / OIL BATH FILTER Conversion..... #1
DIRTROAD
Platinum Member
SOUTH CAROLINA
MF231, MF240, CAT D4K2
Has anyone converted their old oil bath air filter to a more modern replaceable cartridge type air filter?
   / OIL BATH FILTER Conversion..... #2
No, but I want to.
   / OIL BATH FILTER Conversion..... #4
Wondering why you would rather have the non oil bath type?
Me too, a pretty normal Donaldson cartridge is over $30 for the outer. The inner is more. A qt. of oil is what $3? I've never had an old oil type but it seems to make sence unless there is something I don't understand about them.
   / OIL BATH FILTER Conversion..... #5
Leave the oil bath alone. They are proven , have stood the test of time.
The 2 hours that it takes to properly clean the oil bath is why! It would be much quicker to take an air hose and blow a cartridge filter out on a monthly basis and then change it annually. I think I am going to try to adapt something a little more user friendly.
   / OIL BATH FILTER Conversion..... #7
If you use too much air pressure you can put holes in a paper element.
   / OIL BATH FILTER Conversion..... #8
And that could cost you BIGTIME, unless you want to dust your engine out?!
What is two hours? Do it when you do the oil change and maintenance.
   / OIL BATH FILTER Conversion..... #10
I had an oil bath on my ford 1700when i cleaned it I siply dumped the oil out and used a few rags to wipe it clean and then refilled with oil and put back in.It was simple. maybe because it was a small tractor ? Not sure.Im sure it all depends on how much dust gets around the filters. I now have a tractor with a non oil bath. and i have yet to replace it with a new one. I usually just clean it out and knock it clean. its going on 25 years now.BUT I dont get alot of dust action .like haying etc..
2007 INTERNATIONAL TRANSTAR 8600 TANDEM AXLE DAY CAB (A43003)
2007 INTERNATIONAL...
2012 VOLVO VNL SLEEPER (A43003)
2012 VOLVO VNL...
2008 Ford F-150 Pickup Truck (A44572)
2008 Ford F-150...
2019 Chevrolet Silverado 2500HD 4x4 Crew Cab Pickup Truck (A44572)
2019 Chevrolet...
2015 Ford Taurus SEL Sedan (A44572)
2015 Ford Taurus...
New/Unused 20ft x 40ft Container Shelter (A44391)
New/Unused 20ft x...
