"Oil" cap on front gear case???
   / "Oil" cap on front gear case???
Good to know, thank you gentlemen.
   / "Oil" cap on front gear case??? #13
I my Bransons have fill ports on both sides painted yellow for easily recognizing. The one on the left has the dipstick, on the right it doesn't. Drains are on both sides and in the center.
On what oil to use, my 6530 is a 2007 model and the same oil used in the common sump (Premium trans-hyd) was recommended in the Owner's Manual. My 2016 comes with 80w-90 and it's marked on the fill cap with the dip stick and specified in the OM. When I bought my replacement parts for my 6530 front end (which I abused) the seller said that 85w-140 is preferred in our climate. Haven't had a problem since.
If I could I'd put thick oil in the 2400s tranny also but I can't being common sump. Shifting would be smoother and less crunching shifting with the throttle up off idle. The 6530 is shuttle and it doesn't care.
The 6530 holds 2.5 gallons and the 2400 about 1 gallon.
2020 Peterbilt 520 T/A Cab and Chassis Truck (A51692)
2020 Peterbilt 520...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2025 New/Unused Wolverine Brush Cutter (A51573)
2025 New/Unused...
2016 FREIGHTLINER M2 WATER TRUCK (A51247)
2016 FREIGHTLINER...
