Oil Change Question
   / Oil Change Question #11
I thought 100 hour changes were more of the normal.
   / Oil Change Question #12
I'm in agreement with 3RRL. Change the oil before you put it away so it has clean oil with no water in it. Water is a bad thing, it reacts with the acids that build up with use. Some, change in the spring, yhat's ok, but IMHO, not as good as winterizing.
The hydraulic fluid can go 2 seasons if you don't hit the hours.
jb
Thanks to all for the advice. I think I will go with the late in the summer, once/year unless I find something more stringent from mfg.
28013 (A50322)
28013 (A50322)
40ft Sea Container (A52384)
40ft Sea Container...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2015 Toro Workman MD Utility Cart (A53421)
2015 Toro Workman...
2012 FREIGHTLINER CORONADO (INOPERABLE) (A53843)
2012 FREIGHTLINER...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
