Oil Filter Removal on BX22
   / Oil Filter Removal on BX22 #11
I use a K&N filter with the hex cap on the end.
   / Oil Filter Removal on BX22 #12
Nice...until you twist the nut off. Don't use the nut to tighten the filter because sure as shootin' you will overdo it. Snug it up by hand only!! Dutchy
   / Oil Filter Removal on BX22 #13
I never tighten them with the nut -- only to take them off.
FWIW, if I ever strip a filter or know it's wrench isn't going to take it off... I just suck it up, drill a hole and use a thick philips through the filter and start turning.
I see folks bickering with trying to get them off, spending upwards of an hour trying to get one off. I look at it, if it don't come off in the first or second try, only way is to punch a hole. I don't have time to be messing around, lol.
   / Oil Filter Removal on BX22 #14
I bought a 2 finger oil filter gizmo at NAPA in about 2004. It works well on the oil filters on the JDs I've owned. None of them have had hardly any room to use a strap or chain wrench. The finger one just slips over the filter and self tightens itself when you place a socket or socket extension into the rectangular hole on the top.
Use it now for the oil filters on the Mazdas where the Japanese foolishly still place them underneath.
Ralph
   / Oil Filter Removal on BX22 #15
I just take a Phillips screwdriver and a hammer and punch a hole through the filter and lever it off with the screwdriver. It's junk anyway and the holes let it drain.
Problem solved.
New Holland B95 Backhoe (A50490)
New Holland B95...
2015 John Deere 544K Articulated Wheel Loader (A52377)
2015 John Deere...
JOHN DEERE 700M LOT NUMBER 35 (A53084)
JOHN DEERE 700M...
1997 Dynapac CC142 14 Series Double Drum Roller (A52384)
1997 Dynapac CC142...
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A51572)
2013 International...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
