Oil & Fuel Oil for Mahindra?
   / Oil for Mahindra? #1
ditzel
N.J.
Mahindra 2615 Gear
Just bought a used Mahindra 2615 with the mitsubishi diesel. The owners manual says to use 10w 30 oil. What weight and brand oil do you use.
Can I use the same Rotella 15w40 that I use in my duramax.
Thanks,
Tom
   / Oil for Mahindra? #2
If it calls for a 10W/30 then that is what I would use. You can get Rotella in 10W/30 and 15W/40 viscosity's.
   / Oil for Mahindra? #3
ditzel,
What kind of temps are you running in? I have a 2615 and use Delo 15/40 year round in my truck and tractor here in Northern California. Read the manual again. Mine specifically recommends 15/40 Delo, Rotella etc. And I would guess that if you run 15/40 year round in your Duramax it would be fine in the Mahindra.
Also, you might want to try posting in the Mahindra discussion group if you think it is a Mahindra related question.
HangtownMatt
   / Oil for Mahindra? #4
I use 15/40 weight. At my last oil change I used Valvoline.
Also, when it comes to your front axle fluid - Mahindra has changed from gear oil to Hydraulic fluid.
   / Oil for Mahindra? #5
When we service Mahindra's we use Rotella 15w 40
   / Oil for Mahindra? #6
I now use 5W-40 Rotella Synthetic in my 2615 and Duramax because of the winters we have here. 15W40 is fine for summer.
   / Oil for Mahindra? #7
I am wondering about "changed from gear oil to hydraulic fluid." If I can remember till last fall, I think I used gear oil in front. Are you indicating that one should change front axle to hydraulic fluid?
Cheers....Coffeeman
   / Oil for Mahindra? #8
Cheers....Coffeeman
Yes, coffeeman. Hydraulic fluid. I just completed my 200 hr. service. My dealer told me to use it instead of gear oil.
   / Oil for Mahindra? #9
Our Kubota's owner's manual also calls for 10-30, and the only place I could find it was the Kubota dealer, but our local WallyMart just started carrying Rotella-T 10-30.
   / Oil for Mahindra? #10
"Also, when it comes to your front axle fluid - Mahindra has changed from gear oil to Hydraulic fluid."
Can the hydraulic fluid can be used in the front axle of 2015? Thanks.
2017 Versatille 260 (A60462)
2017 Versatille...
Club Car Carryall 500 Utility Cart (A59228)
Club Car Carryall...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2021 KENWORTH T680...
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
14C SCRAPER (A58214)
2012 CATERPILLAR D4K LGP CRAWLER DOZER (A60429)
2012 CATERPILLAR...
