Oil for new 21 HP Kawasaki FR651V SCAG mower engine
   / Oil for new 21 HP Kawasaki FR651V SCAG mower engine #61
I don't subscribe to to the idea that the second you put 30 year old oil into a new engine it's going to detonate like a nuclear bomb. Chances are if you do have a problem it'll be slightly more wear when the engine is cold and possibly fouling plugs. You also could be down on power. I watched a show about what happens when the wrong weight oil and having too much oil in a car engine. They used a dyno to show that oil actually robs some power in those conditions. I'm sure you will not notice a 1% or 2% loss in power. If it was me, I would turn the bottles up side down (making sure the caps don't leak) and let them sit for a few days so anything that has settled to the bottom has a chance to migrate towards the top.
The weight of the oil I was considering is well within the mfg. recommended range.
   / Oil for new 21 HP Kawasaki FR651V SCAG mower engine #63
Fried,
I'm over 60, and all my engines (10 of the 15 are 18-30+ yrs old) are running well and my cylinders have good compression too :).
I expect they will outlast me no matter what oil I put in them as long as its used regularly and changed often.
Fried,
EXACTLY!
I'll be 80 in November!
One of my sons will inherit the SCAG,.....and a WHOLE lot of other good stuff!
   / Oil for new 21 HP Kawasaki FR651V SCAG mower engine #65
If I was 60 again, I'd be a who*e.......:D
I have the same Kawolski engine in my zero turn (not a Scag) and it had 3500 hours, all on T6 Rotella. Just one valve adjustment is all it takes. Got the original plugs in it too.
I use Rotella 15W-40 in everything, except 2 cars, with Mobil 1.
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2015 FREIGHTLINER...
Flat bed utility truck with inline 6Cy engine (A55301)
Flat bed utility...
UNUSED SWICT 72" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 72"...
40ft 6-Door Shipping Container (A52377)
40ft 6-Door...
2016 John Deere 5055E 55HP Utility Tractor (A52377)
2016 John Deere...
