Oil pan drain plug
   / Oil pan drain plug #1
Tallman
Northwest Pa.
1300 Ford 2 wd
I've got a Ford 1300 that has the oil drain hole threads stripped. I am looking for a way to repair. Any suggestions would be appreciated. The plug is still in, but i need to change the oil soon and trying to figure out what to do.
   / Oil pan drain plug #2
Take your drain plug into a auto parts store and tell them you need a drain repair plug. They have a plug that screws into the damaged threads and has a plug in it.
   / Oil pan drain plug #3
There are a bunch of ways to fix it - from cutting out the old drain plug hole and welding a new one in, to using one of those expandable rubber plugs. In a pinch, I'd use one of the expandable ones - just change it every time you change oil so that you're sure it is in good shape and making a good seal. You can get them at pretty much all the auto parts stores, and they have ones that expand by turning a wing-nut, screw, or regular nut.
   / Oil pan drain plug #4
Buy the next size up plug, drill and retap. Good as new. /forums/images/graemlins/wink.gif
   / Oil pan drain plug #5
Jerry's suggestion is the cheapest, best and most permanent way I know of.
   / Oil pan drain plug #6
I've seen a variation on this...a series of plugs of the same dia and pitch w/ progressively deeper threads. Basically, you use the new plug (w/ deeper threads) to chase those stripped out in the drain pan. Winding it in is a chore but it seems to hold pretty good and tends to deform instead of cut so you don't have to worry w/ metal bits in the pan. The beauty is you don;t have to remove the pan.
   / Oil pan drain plug #7
I had a pontiac sunbird that had buggered up oil drain threads.. I got one of those 'tapping' repair plugs. It was washer headed, and came with a nice rubber gasket. The plug cut decent threads that held well.. and the gasket sealed good.
I put a dab of grease on it and put some grease up in the pan to catch chunky metal bits.. I also ran a couple quarts of oil down the oil fill and out the pan to clear the grease and filings.. I sold the car after 4 years and the other owner had it at least 4 years...
Soundguy
2016 CATERPILLAR 304E2 EXCAVATOR (A52709)
2016 CATERPILLAR...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58214)
2011 MULTIQUIP...
More info coming soon! (A55851)
More info coming...
2019 Chevrolet 1500 Silverado Crew Cab Pickup Truck (A55973)
2019 Chevrolet...
Mini John Deere Truck (A55853)
Mini John Deere...
2016 Ford Explorer AWD SUV (A54815)
2016 Ford Explorer...
