Checking a few of the pdf manuals I have on hand - FIL's Cub 7260 Service Manual shows torque values for the trans drain plug, but nothing for the oil pan. The Owners's Manual DOES have a torque spec for the oil pan plug.
I only have hard copies for the Kubota. Will check in a few.
Update: Y'all are exactly right for Kubota. Neither the Owner's nor the Workshop manuals list any torque spec for the drain plugs anywhere. Just "reinstall the drain plug". About the only thing the Owner's has is rear wheel bolt torque. Lotsa specs for most everything in the Workshop, but not those plugs. I did notice that the "general" fastener torque specs have different values for not only bolt material/grade, but also for what it threads into, either "Ordinariness" (;-) or "Aluminum". 9T bolts are only used for "ordinariness".
