Oil Question
   / Oil Question #11
N1ST said:
I take it that the diesel oil certification satisfies the gas engine oil reqs but not the other way around?
There are 2 separate API ratings, one for diesel engines (Cx) and one for gasoline engines (Sx). Many oils list both classifications. If they don't, you can't infer a certain diesel rating meets a certain gasoline rating.
   / Oil Question #12
As MikePA said they are not the same and neither swings both way's. Commercial C category (diesel) engine oils tend to have a much more robust additive package than it's Service S category (gas) counterpart. However, some C category engine oils have a additive package that have additive levels that are to high to pass the S category. Some oils are single API rated while others are multi rated as both C and S category. For a simple description of the API certification category system it's probably best to view the API's website info. http://www.api.org/certifications/engineoil/categories/upload/EngineOilGuide2006.pdf
   / Oil Question #13
DieselPower said:
You should be fine with a multi-visosity like 5W or 10W/30. Many manufacturers of small engines are starting to spec multi-viscosity oils in their engines these day's. They just seem to be a few decades behind the auto industry.
face it, 90% of small equipment is only used in summer months and SAE30 probably gives marginally improved protection over 10w30 in those applications.
other than that, oil doesn't hardly matter in a Briggs, I've seen more than one of them running around without any slippery stuff inside the crankcase. LOL.
2019 KEESTRACK K6 SCALPING SCREENER (A51246)
2019 KEESTRACK K6...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
INOP/NON-RUNNING 1999 International F-2574 Fuel Lube Truck, VIN # 1HTGGATT4XH682675 (A51572)
INOP/NON-RUNNING...
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
