ok here is the 3ph to sleeve hitch adapter after
   / ok here is the 3ph to sleeve hitch adapter after
</font><font color="blue" class="small">( Well it ain't pretty /forums/images/graemlins/blush.gif but if it's functional, who cares. Besides paint hides a lot of stuff /forums/images/graemlins/grin.gif I think you will do just fine and it sure is a lot cheaper than going out and buying all new stuff. I know I didn't want to spend a lot as I only plow once or twice a year. Now if I could just get a cheap tiller for the back then I could give up the walk behind /forums/images/graemlins/laugh.gif
)</font>
I have to rebuild the Carb on my walk behind. Will probably get away with just cleaning it real good a couple more times but it really needs to be replaced.
I couldn't give my little 5 horse tiller up completely even if I did get one to go on the tractor. I use it to till in tight place a lot, that a big one just wouldn't fit.
</font><font color="blue" class="small">( Are you sure that you didn't send that to me and I welded it? It sure looks like my welding!! I do need to make the same thing, give me some details on the Cat 0 end of your hitch. I have a plow like that and would like to use it. Thanks, honestly, I don't weld good enough to comment on someone else's work- if it holds, who cares. )</font>
I basically started off with a manual sleeve hitch that was mounted on the MTD gaden tractor. I cut the arm off the side that the MTD used to raise and lower the hitch and mounted it on top, welded that and a bunch of braces on it and that was pretty much all I did. Oh and then (after I was done of course) I found a brand new top link bar off of a john deere in my garage, that the previous owner had left up in the rafters.
I will take some close up pictures and send you the link If you would like me to
   / ok here is the 3ph to sleeve hitch adapter after #13
Strong welds arn't always pretty until you use the grinder. There isn't anything I welded together that my life depended on thats come apart.
   / ok here is the 3ph to sleeve hitch adapter after #14
Looks good to me, should work fine. You should see some of my welding before grinding /weld more/grind more/painting /forums/images/graemlins/smile.gif
As long as it gets good penetration and does not fall apart.
For me vertical welding with a buzz box is difficult at best /forums/images/graemlins/smile.gif
Gonna get me some big honkin diodes to make my buzz box DC.
Ben
   / ok here is the 3ph to sleeve hitch adapter after #15
You say you need a tiller? With that set up you could put a gang bar across your unit, get two to four garden tillers side by side, mount them with an easy hitch system fire them up and move out. what we do with tractors reminds me of the red-green show.
   / ok here is the 3ph to sleeve hitch adapter after #16
Now that you have the plow mounted, we want to see pics of freshly turned soil, complete with the smell of fresh earth if you can accomplish that. /forums/images/graemlins/smile.gif
Ok I will take some pics of the freshly plowed Garden spotS
tonight if I get home before it is too dark, if not you might have to wait awhile as we are expecting some significant snow. But I know how that goes..... I got the Kubota this year and am ready to plow so there won't be anymore snow. /forums/images/graemlins/grin.gif
2015 CATERPILLAR 262D SKID STEER (A51246)
2015 CATERPILLAR...
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
2016 Ram 4500 Chassis Truck, VIN # 3C7WRKFJ7GG229313 (A51572)
2016 Ram 4500...
UNUSED MOWER KING ECSSTR072-72" HYD TILLER (A51248)
UNUSED MOWER KING...
2014 Club Car Electric Golf Cart (A51694)
2014 Club Car...
2018 Seal Rite SR 700XP Seal Trailer (A52384)
2018 Seal Rite SR...
