OK Man Run Over By His Own Tractor
   / OK Man Run Over By His Own Tractor #11
The only think I can think of is that he left it in gear, and it had a clutch arangement that you can lock the clutch 'out'.. and then the clutch kicked in and started the tractor going. A hand clutch tractor comes to mind. I can leave my JD-B in gear and push the clutch out.. If I don't push it all the way out, the detent doesn't lock in and the clutch can swing back in due to vibrations.. thus making the tractor start moving... That's why i like to take the sucker out of gear when i stop.. etc..
Still.. I agree.. I think he's running a line of BS to make himself look less stupid, and shift the blame to the machinery, instead of the thick headed operator, whose error it really was...
Soundguy
   / OK Man Run Over By His Own Tractor #12
You hear about this stuff on old equipment, but I have a buddy that bought a Landtrac new the same time that I bought mine. He had to jump off when he hit a beehive while brushcutting, and it kept going and the cutter just kept cutting. He ran like crazy to catch it before it mowed into the next county. I can't believe that a recently manufactured machine could be set up this way (he hasn't modified it...) No pto or tranny safety switches at all.
   / OK Man Run Over By His Own Tractor #13
I wonder if he and others aren't using the starter with the tractor in gear to nudge the tractor forward/backward while attaching implements???????????????
Their logic would be "it will only move it an inch or so, so I can attach the implement". And with it being in gear, it wouldn't roll the other way when the starter released.............
I can see folks trying that. Sure sounds dangerous to me!
Ron
400 Gallon Fuel Tank with Stand and New Pump (A50325)
400 Gallon Fuel...
2008 Ford Escape Hybrid SUV (A51694)
2008 Ford Escape...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
500 Gallon Fuel Tank, Pump, Hose, and Nozzle (A50325)
500 Gallon Fuel...
