old field to decent lawn
   / old field to decent lawn
Thanks for all the great advice, at least now I've got a place to start next spring. And it looks like I've got a lot of work to do. I plan on living here for quite a while, and if I'm going to do this, I'm going to do it right and have something to show off and be proud of.
One more question I have: is it necessary to plow before disking? One person (not here) said I could disk the ground and that would do it, but we have heavy clay soil and when it's dry it's like concrete. I doubt this area of the former farm was ever plowed before, if that helps.
And yes, I'll try to get some pictures up, too.
   / old field to decent lawn #12
</font><font color="blue" class="small">( One more question I have: is it necessary to plow before disking? One person (not here) said I could disk the ground and that would do it, but we have heavy clay soil and when it's dry it's like concrete. I doubt this area of the former farm was ever plowed before, if that helps. )</font>
I think you'd find it easier to plough first, but it's not an absolute.
If you have enough weight on the disks, and run them over a few times in different directions, you may be able to tear it up enough to satisfy your needs. If the clay is hard and packed, you may find it better to plough first, or save a lot of work and use a good strong tiller. John
   / old field to decent lawn #13
If you have enough horsepower and a very heavy disc it will work. Otherwise plough first. You will end up with a much better job.
For planting think about keeping the area black for at least a month or so to give all the seeds that are in the ground a chance to sprout and be worked under. Every time you work it it will also help smooth and level.
Instant viable lawn is a myth - even when turf is used!
I've got nothing against a disc , it's just that they require more HP-Traction than most of us have.
Egon
   / old field to decent lawn #14
You'd be surprised how well it could look if you just mow it more often.
Here are two BEFORE/AFTER pictures of when I bought my property and how it looked about 1 year later:
Photo 1 | Photo 2
And here is another set for good measure:
Before | After
   / old field to decent lawn #15
</font><font color="blue" class="small">( ( You'd be surprised how well it could look if you just mow it more often.
Here are two BEFORE/AFTER pictures of when I bought my property and how it looked about 1 year later: ))</font>
Bah! You Photo Shop'd those pics! /forums/images/graemlins/smile.gif
All seriousness aside, I agree mowing is the best way to kill weeds and rough grasses. Just mowing and filling puddles will usually make a nice looking field. I also did the same thing you did, turned out good.
Egon--
What would you say is "enough" HP??
Dave--
Yeah, I agree that mowing can do a lot. I used that method on the west side of the house, bush hogging, rut filling, seeding and mowing. Turned out nice enough, too.
However, in that area, like in your pics, it was all just high weeds. The spot in question now has patches of scrub and brush. Sure I could run the bush hog over it first first, but what about all those small stumps?? And there is considerable rutting, too. That would take lots of fill, and I've got no FEL to help.
   / old field to decent lawn #18
Oh - starting at about 150 HP on up. This is for breaking sod, not discing worked land.
Egon /forums/images/graemlins/grin.gif
2016 KENWORTH T270 SERVICE TRUCK (A51406)
2016 KENWORTH T270...
2012 Infiniti G25 Sedan (A53424)
2012 Infiniti G25...
230112 (A53422)
230112 (A53422)
CAT 416B (A47477)
CAT 416B (A47477)
2016 Peterbilt 567 Tri-Axle Dump Truck (A51692)
2016 Peterbilt 567...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2018 FREIGHTLINER...
