Old hog
/ Old hog #1
tbb2383
Outside Buffalo, NY
2003 New Holland TC40D
Hi, folks. My first message here. We recently bought 12 acres of bush, and overgrown fields, and I found a NH TC40D for sale on my way to work. It is now in my garage, and I got an old 6 ft bush hog with it. The blades are worn almost round and tear rather than cut. I've never done this before, but assume that new sharper blades will do a better job. Is it worth trying to sharpen, or since they have lost a fair bit of metal should I replace them? Thanks for any help. Tom
/ Old hog #2
First Off - Welcome to TBN!!!
Sharp blades will cut better, but some folks prefer them on the dull side when hitting heavy brush, as the shredding action on the remaining stubs keeps them from becoming a nemesis to proper tire inflation...Blades as worn as you say, sound like they should be replaced though. Maybe hit it once with the dull blades, and then replace...
.02 as always,
Lunk
/ Old hog #4
You could use an angle grinder to put a square edge on the rounded blades first. Grind some of the top bevel down to remove as much material as you have time to do, making a somewhat narrower/sharper cutting edge. Then clean up the leading edge a little more by squaring it off. The squared edge will cut better than the rounded edge, but still act as a hammer to shatter the stumps/stubs as it cuts them. Also, try to set the cutter up so it is 1-2" lower in the front than the rear while cutting to reduce the effort needed to cut. Doing both of those things will give you more free horsepower to give a better cut. New sharp blades will give a better cut on grass, but I notice no difference in the heavy stuff.
Good luck.
/ Old hog #5
Ditto that.. put about a 1/8 to 1/16 flat on the blades.. that will shatter studdy sapplings and prevent them from growing back.. plus won't make sharp spears to puncure tires... shoul still cut grss as well.
look the blades over.. if there are any cracks, especially near the shoulder bolts.. replace both.
if no cracks and the blades are just well worn.. sharpen them up as indicated and get a lil more life out of them. do make sur ethe box has lube in it.
soundguy
COLEMAN CK100-S GO CART (A63745)
COLEMAN CK100-S GO...
2021 P&J 40' GOOSENECK TRAILER (A63745)
2021 P&J 40'...
2005 Jeep Grand Cherokee SUV (A59231)
2005 Jeep Grand...
(2) 275/80R22.5 BF GOODRICH TIRES & ALUMINUM RIMS (A63745)
(2) 275/80R22.5 BF...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
Oxy-acetylene Torch and Regulator Rig (A63118)
Oxy-acetylene...
