Old kubota B6100-d needs help
   / Old kubota B6100-d needs help #1
Barney6595
Grants Pass, Oregon
kubota B6100-D
Kubota B6100 - Looking for the 2 rear axles used okay,
also 3 point hydrolics raise ok but won't hold and bleed of immediately. Is this a hard fix like the clutch was?
   / Old kubota B6100-d needs help #2
Good luck on finding parts. You 'bleed off' is the rockshaft piston ring that is failed.
Thank You, I'll look that up, I do have the old original owners manual.
   / Old kubota B6100-d needs help #4
You'll need a shop manual for that I suspect. On the older Kubota units, the rockshaft casting and internal piston and linkage come off from the top of the gearcase. Not a big job but parts may be an issue.
thanks, I was looking at the diagram and wondering where the entry point was. Looks like there are a couple of o-rings and a seal in there. it would be nice to get rear hydrolics working. Right now I use the Manual method - ratch strap come-along to adjust hieght.
2008 FORD F450 SERVICE TRUCK (A54607)
2008 FORD F450...
2014 CATERPILLAR 305E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A54811)
2010 Turfco...
AUCTION STARTS HERE @ 9AM (A52706)
AUCTION STARTS...
2015 KENWORTH T680 SLEEPER TRUCK (A54313)
2015 KENWORTH T680...
