Older 763 with hydraulic leak on switch(?)
   / Older 763 with hydraulic leak on switch(?) #1
Fred Bryant
Wenatchee, Wa
Bobcat 763
Older 763 with hydraulic leak on switch(?) next to hydraulic filter. It is peeing a stream of hydraulic fluid out of the electrical connector ( ~ 1 gallon/hour ).
It does not seem like it would be hard to change. Please correct me if I am wrong, but it looks like a discontect electrical harness, unscrew old, screw in new, and then reconnect electrical harnness. Right/wrong/does it need sealant of some sort/...?
I am out in the boonies, with no manual, etc, so I need to order it online and have it shipped to the local ( 20 mile away ) post office. Simple question: What is it and where can I get it?
Thx's, Fred.
   / Older 763 with hydraulic leak on switch(?) #2
Your plan for repair seems pretty accurate. If the switch is threaded into the hydraulic filter base itself or into the suction line between the filter and pump, it's probably a vacuum switch designed to trigger a warning light indicating a filter restriction. As for where to get one, you will need to call a dealer with model and serial numbers handy, and let someone look up the part number for you.
2018 Freightliner M2 106 Lay Flat Roll Back Truck (A55852)
2018 Freightliner...
2015 Freightliner M2 Chipper bucket Truck (A52377)
2015 Freightliner...
2010 INTERNATIONAL SF647 TRI-AXLE CRANE TRUCK (A55745)
2010 INTERNATIONAL...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
2006 FREIGHTLINER COLUMBIA 120 (A55745)
2006 FREIGHTLINER...
Case 1083 20ft Corn Head (A55315)
Case 1083 20ft...
