farmallbill
Bronze Member
- Joined
- Nov 22, 2011
- Messages
- 63
- Location
- Northern Pa
- Tractor
- farmall m, Allis Chalmers WD x2, Husky 390XP, Husky 455 Rancher
The best thing is check the flywheel housing and see if there is a cover with 3 bolts where a starter would mount, or see if you can see in the casting of the flywheel housing where a starter should mount, this is more of a difficult job, you will have to get a hole saw and drill out the flywheel housing and then drill out and tap the holes to install the starter bolts. If you have either of these contact your local Cat dealer and tell them you need a starter conversion. I work at a dealer and we have sold numerous kits through a guy in Texas. they are a nice kit that comes with starter, wiring, switches, instructions, etc.
