Older Woods Rotarty Cutter
   / Older Woods Rotarty Cutter #1
moship
PA
Kubota L3130 HST 4x4 Kubota L4740-3 HST
I'm looking to buy a used rotary cutter and just looked at an older (perhaps very old) Woods 60" cutter. The guy said he bought it 3 years ago from a dealer, but failed to tell me that it was used prior to that. That's OK, but I was expecting it to be much newer. There is no way of telling how old it is other than it doesn't look anything like the ones posted on Woods website.
It has been painted over many times, but the Woods decals are still visible through the paint. Unfortunately I couldn't find any other identification on it. It has the typical signs of being used and setting outside, but nothing too bad. The PTO shaft and clutch didn't have all the protective covers but the u-joints seemed solid. With regard to the PTO shaft I'm only concerned about the slip clutch.
The owner started it up and it turned over find, but it did seem like the clutch on the PTO might have been slipping when the PTO was first engaged (first 1 to 2 seconds).
Cosmetically it is used. The blades seemed to be tight and I question how hard they would be to remove to lubricate, sharpen or replace. Perhaps replacement blades are not available.
I plan on using this to clear some trails and will likely run into a number of stumps, small trees or brush.
Questions:
1) Is there a way to ID approximate year or model for replacement parts?
2) Are replacement parts still available? Or has the designed remained relatively unchanged over the years?
3) Can the PTO clutch be rebuilt and are they generally of a standard design?
4) Is an overriding pto adapter needed for correct operation? The cutter was behind a very old Oliver tractor and it had an overriding adapter between the tractor PTO output shaft and the Cutter PTO shaft.
5) What is a stump jumper with respect to this implement?
Before anyone asks, I forgot to take a camera along.
Thanks in advance for any help.
   / Older Woods Rotarty Cutter #2
I have an 1996 60-inch Woods Cutter (MD160) -- no problems getting parts. I bought new blades earlier this spring and easily changed them. The dealer had them in stock! Mine has a stump jumper, which is a round device (as opposed to a crossbar) upon which you mount the two blades. Prior to this one, had a Woods Cadet model and those are still supported too.
LouieJunior,
Thanks for the reply.
Is it possible to post a picture of your cutter, so I can compare with this one? This one had a squarish shape to the back (wheel side) and not angled or rounded like the newer ones.
Everyone,
It did not have a stump jumper. The crossbar is exposed. It seems like the stump jumper is a necessity to clear stumps and rocks (my main concern). Is this a true assumption on my part?
The blades didn't seem to be as thick as the ones I seen at TSC last evening.
I've never had a PTO with slip clutch. When the PTO was first engaged there was some chatter almost like gears engaging/disengaging coming from the gear box area. Is this the slip clutch slipping?
   / Older Woods Rotarty Cutter #4
Here is a photo of my MD-160 cutter.
Thanks for being so kind to post a picture of your rotary cutter. The one I looked at didn't have the chamfered rear corners like yours. In the back (wheel side) it was straight across. If viewed from the top (birdseye view) it would look like a square or rectangle.
Any guesses on what other model number it could be?
   / Older Woods Rotarty Cutter #6
moship you'll have no problems getting parts for a woods mower. I have a squarish one with too from the early 90's, 4 wheels at each corner.
When you first start up for a new season they just sound weird for a few seconds.
As far as removing the blades I use a long pipe and breaker bar...and that's with the threads previously treated with never seize.
What's the gentleman asking for the mower? btw imo Woods of that era is a quality heritage mower.
UNUSED FUTURE ST60 HYD SIDE SHIFT FORKS (A54757)
UNUSED FUTURE ST60...
VOLVO EC240CL LONG REACH EXCAVATOR (A52705)
VOLVO EC240CL LONG...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
Engel 20' Boat (A50121)
Engel 20' Boat...
1990 KME (A53424)
1990 KME (A53424)
2016 Ford Explorer AWD SUV (A55758)
2016 Ford Explorer...
