?on Cat D8 engine oil filters -
   / ?on Cat D8 engine oil filters - #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Was going over our oil filter charts here at work and noticed we are buying Napa 1161 filters for our cat D8 ( takes 2 - cartridge canister types)
From Napa, those list as transmission filters.
going back to the original cat # of: 5S484 I find lots of crosses... donaldson, fram, baldwin, napa, wix, and **many** others.
About half of them mention HD full flow 'lube' filter, and half mention one or both of hyd or transmission application.
Looking at the cartridge specs, seems to be pretty uniform across the manufactures, no matter what number you use.
Should I be finding a different cartridge other than this 1161 ??
From looking at our paper charts ( putting them in a computer database is how I found this )... we have been doing this for a loooooooong time.. so obviously the napa tranny cartridge hasn't killed the D8 in the last 20 years..
thanks
   / ?on Cat D8 engine oil filters - #2
1R0659 is the current number from the old 5S0484 number. Try that number in your cross reference between manufactures. As long as the micron rating of the filter media is close to stock,and the flow is sufficient, it should be fine. Those old CAT's are pretty durable, assuming it is a D8H?
There were other numbers that have long since changed to the newer 1R0659, which were used in transmission and clutch systems.
Nothing wrong with with using good filters, you don't want the filter to go to bypass.
Yup, 1R0659 also crosses to a Napa 1161..
Guess its not gonna kill her after decades of use. ;)
12ft Utility Trailer (A54865)
12ft Utility...
New Quick Attach Hay Spear (A54865)
New Quick Attach...
2010 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTN6 LIGHT TOWER (A55745)
2010 WACKER NEUSON...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2011 Ram 1500 4x4...
1999 VaXcavator VT500D T/A Towable Vacuum Trailer (A55851)
1999 VaXcavator...
