Here's an update. I went and looked at the tractor.. Last time I had looked thru a fence at it. Also talked to the salesman. The info I was given earlier was for a different mower thaey had already sold.
This one is an older rhino.. perhaps an old flex15.
Here is the info, I want honest opinions.
Hoses good, rear wheel rocker has been replaced.. wheel bearing good.. the 4 boxes don't have any 'drip' leaks.. though there is a small residue around the shaft seals. I tried jiggling the shafts and detect no discernable movement.
The center blade gearbox has been apart at one time as there is old gasket goop extruded out of the rear cover surface. Looks to be an old repair as the good has some of hte old mower paint on it.
Pto shafts still have shields.. they are aged, but intact. 1000rpm pto hookup collar moves smoothly.
The drawbar hitch is beaten up pretty good.. has mushroomed the metal in a few places.. but overall is still structurally intact.. very beefy metal.
I found -0- welds on it. A minor dent or two.. No blade grooves ont eh decks.. stump jumpers were solid.. no sign of lower shaft leaks.. and no play in stump jumpers to output shafts.
the metal on each wing, right at the fold is rusted thru right at the place where the flat of the deck hits the square that makes the 'hinge'...say.. about 18" on each side., Metal 1/2" fromt he rust thru is solid again. All the world looks like you could buy a 3' piece of 1.5" angle iron.. cut it in half.. lay it in place and burn a rod up and down each side and call it 'done'.
No evidence ov leaks at the wheel lift cyl, or the batwing cyls.
Price is 2700$.. plus I'd have to get the 1000rpt conversion shaft for my tractor pto for another 330$
I looked it up and down for an hour. The rust outs didn't thrill me.. then again.. they look like a 1 hour fix. The drawbar hitch is beat.. but doesn't show any sign of giving up before any else of the tractor does due to the thickness of the metal used.
Real and honest Opinions.
Financially.. I've determined that I can throw it on a credit card, and I won't have to eat hot water and ketchup or anything... Wife could go either way.. left it up to me ( great... /forums/images/graemlins/blush.gif ). I already have a 10' mower.. so time savings on mowing will be 33% or less.
My mind tells me this is not a 'deal'.. but not a ripoff either.
I'd prefer to have this in 6spline 540rpm pto.. but have been told that 1000 is actually better for the big stuff.. so I guess i will defer to that info.. as I have -0- experience ont he big mowers and 1000rpm pto.
Ok guys. Do I pick it up.. or pass it by?
Soundguy
