One ton 3pt ballast ...
   / One ton 3pt ballast ... #1
JerryK
Elite Member
Vanderbilt, Michigan, USeh?
Mahindra (2011)5035 HST TLB & (2016)2555 HST Cab & (2017)1526 HST(2018)Cub Cadet Pro Z 154L (1991) Caterpillar E70B
Howdy, this is my version of a 3pt ballast to use when using the loader. Looked at many different posts, ideas, etc... and decided to build it this way. There is no provision for a two inch receiver...I have other tractors to move stuff like that. But I did drill some holes in the 3pt angle to maybe attach some pipes for tool handles in the future... I welded 8" of genuine Mahindra drawbar that sticks out the top for lift point if needed.. The finished cement is 42" wide, 34" tall, and 18" thick ... and I poured it on it's back. Steel weighs a little over 135 pounds and concrete about 1900 pounds ... almost 24 full bags of Quikrete.
   / One ton 3pt ballast ... #2
so how close DOES the concrete sit to the back tires? judgeing from the pictures i wouldnt be surprised if you cant actually mount it to the back of the 3pt without it interfering with the rear tires.
Lot's of clearance on my shiny new Mahindra 5035 with 19.5LX24 R4's with Cat 1 bottom pins, and even more on my JD 2240 which is Cat 2 and 16.9X28 R1's .... The bottom links stick out farther back than the tires. I want it tucked in as close as possible, I live in a sugar maple/beech forest and I want to do as little damage backing into stuff as possible... Not much fun with the backhoe on... :)
   / One ton 3pt ballast ... #4
That's a great idea. I have a few dead 3pt implemts laying around...an old brush hog would work perfect.
   / One ton 3pt ballast ... #5
Looks great... Post a picture with it attached to your tractor.
Thanks
Thanks
Will do, Stan..! I have it watered down and covered with plastic now, and will be taking the forms off in about a week when she cures. IF I can remember where I put all the screws holding it together by then.... :) Hope the fires are staying away from you down there....
Finally pulled it off the pallet I poured it on this morning... THAT is a story in itself, moving a pallet with a ton on it without any weight on the back of my tractor. I was two wheeling most of the time. I will usually operate this weight about six inches off the ground...unless I need to clear something higher... There is a pucker factor when you first drive a tractor with a backhoe on a slope, and this new weight has me cringing in the seat now, too... Especially seeing how tippy a tractor gets with a lot of weight on the loader end...even with the load close to the ground.
   / One ton 3pt ballast ... #9
I worked with a guy who looked like that ballast. His head was like a block of concrete, the 3pt hooks look like his eyes, and the top link attachment is his mouth.
You do better concrete work than the contractors I've hired. They just do anything to get out and get their money. That's why I end up doing everything myself. I'm curious how much your loader can lift.
   / One ton 3pt ballast ... #10
A very well done project. :thumbsup: Do be careful around slopes. Also stabilize the block to prevent it from swaying side to side.
2004 Chevrolet Silverado 2500HD Service Truck (A53422)
2004 Chevrolet...
2019 John Deere XUV560E Utility Cart (A53421)
2019 John Deere...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
2021 WESTERN STAR 4700 DUMP TRUCK (A55745)
2021 WESTERN STAR...
2018 KENWORTH T880 DAY CAB (A56129)
2018 KENWORTH T880...
