One ton 3pt ballast ...
   / One ton 3pt ballast ... #21
Well done! When you go into production I want one! All CAT 2 pins. It would be perfect for my 6415
   / One ton 3pt ballast ... #22
I need one with hooks so I can back up to it with the box blade then lift the box blade.
I had a pallet of horse feed pellets on the FEL las night and the back end was off the ground.
My wife needs to gain a few pounds cause her weight just wasn't enough to counter 12-80 pound bags of pellets.;)
RC
RC
Nice ASA patch.. I was in Frankfurt behind the Farben Building, then spent a year and a half in Nam [ got there just before Tet ] for the 509th [ 1st Radio Research, then 224th Aviation ], came back...got assigned to the airborne in Brag [ playing golf and eating donuts ], then finally back to Fort Gordon for an instructor [ hated that ]....
Super nice ballast setup. I was thinking of something similar. How does it handle with this ballast on?
The hoe only weighs about 1500 pounds, and the 2K# ballast sets it down more in the rear. Don't have to worry about lifting the rear when using the FEL, but I ride around with it only about 6 inches or so up off the ground. The hoe CofG is probably higher than the ballast, but I am still a newbie using it on the back... and still worry about a quick upside down flip every time I raise it up. Didn't seem to bother me riding around with the hoe on, but ever since I saw how tippy the tractor is when using the FEL without any weight on the rear, I need to be retrained.... Probably should have made it more T shaped on the bottom, and maybe knock off a couple hundred pounds...if I did it again.
   / One ton 3pt ballast ... #25
Could also add some green or yellow dye to the concrete...... Just saying.
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A53422)
2007 Ford F-150...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
2018 BOBCAT T740 SKID STEER (A52706)
2018 BOBCAT T740...
