Only 5 Attachments
/ Only 5 Attachments #21
As you can see, it really depends on your place and the plans you have for it. If you have a few acres (5) like we do you will need something to mow with, something to till with and something to do some land grading with.
Mower, box blade or rear blade, tiller, landscape roller and if at all possible, a backhoe.
KB
/ Only 5 Attachments #22
1 Grapple for FEL
2 Bush Hog
3 Sprayer
4 Finishing Mower
5 Spreader
That beer cooler has got me thinking that I may have to revise my list.
/ Only 5 Attachments #23
1. bush hog
2. box blade (w/integrated reciever & gooseneck hitches)
3. bucket grapple
4. landscape rake
5. plans for a log grapple
My brother has the PHD & subsoiler.;)
/ Only 5 Attachments #24
Prioritized by wish/wanna or usefulness/price ?
If someone else is paying - the genie appears and holding up 4 fingers (& a thumb) says...
OK, if I can't use one of them to swap the tractor for a much bigger one.
Back hoe; useful, handy, expensive and probably not THAT good a usefulness:cost ratio.
Rake; To save my wishes the ALL OPTIONS KIT with scarifiers and drop board.
Box blade;
Roto-tiller;
Mower; probably flail.
I would swap the tiller for a plow if "farming" vs "gardening".
The box blade could be swapped for a grapple if needing to clear land.
I'm assuming the Genie says I can't take (for example) a Harley rake and sell it next week to buy two or three different attachments.
Gee, that is not at all original - other than that I have separate rake and rear blade, I have those plus a few more already.
I need to write to Santa anyway, I've been (reasonably) good this year.
/ Only 5 Attachments #26
Hard to answer for everyone but these are what I use the most.
rotary cutter, box blade, landscape rake, phd, grapple.
/ Only 5 Attachments #27
I don't have a tractor yet but if I did these would be the attachments
Rear blade
Box blade
Forks
PHD
York Rake
KC
/ Only 5 Attachments #28
Based on what I use most of the time, my list is:
Bush Hog, 5'
Sprayer
Chipper with shredder
Box Blade
Tiller
Followed by:
Boompole
PHD
Carryall
Rake
Bucket forks
Flail mower
Aerator / Spike Roller
Pulverizer
Cultivator
Rear Blade
Shredder mower, 4
Backhoe (still not hooked up) :(
/ Only 5 Attachments #29
I'm not sure that I could get by with 5. Too much to do but here goes and I leave open the option to change my mind.:D
Brush Hog
Disk
Chain harrow
Fertilizer, seeder spreader
Box blade
/ Only 5 Attachments #30
Box blade, back hoe, MMM, PHD, drag harrow. I have all but the box blade.
/ Only 5 Attachments #32
Backhoe
Box blade
Rotary cutter
yard rake
hydraulic dump trailer
/ Only 5 Attachments #33
"Me thinks it should be changed to 10."
That would be good---I want my CHIPPER back!
/ Only 5 Attachments #35
1) Rotary Cutter
2) Box Blade
3) Backhoe
4) Tiller
5) Spreader
/ Only 5 Attachments #36
BH, Winch, Tiller, box blade, chipper.
(I currently only have the first 2 items)
/ Only 5 Attachments #37
Bush hog, Rake, Rear blade, Plow, Carry-all.
Solo
/ Only 5 Attachments #39
1. Disk
2. 2 row 71 planter
3. tiller
4. middlebuster
5. rear blade
I am glad I don't have to be limited to 5 because I would hate to give up my bush hog, plow, or sprayer
/ Only 5 Attachments #40
rotary cutter,box blade, disk,2 row panter,2 row cultivator.
2019 International LT625 Sleeper 48 (A62613)
2019 International...
1996 International Water Truck with a Caterpillar Engine (A63118)
1996 International...
UNUSED WOLVERINE MSG-11-44W 44" HYD STUMP GRAPPLE (A62131)
UNUSED WOLVERINE...
UNUSED ATS GAC40Y 40 GAL.AIR COMPRESSOR (A62131)
UNUSED ATS GAC40Y...
2014 Wells Cargo T/A Enclose Trailer (A61569)
2014 Wells Cargo...
2004 Mack CL713 Tri-Axle Heavy Haul Truck, VIN # 1M1AD64Y04M001417 (A61165)
2004 Mack CL713...
