I contend that the type pump determines whether a hyd system is OC or CC then for system to function properly the correct type control valve must be utilized. You can't tee a OC control valve on a CC pump and turn system into an OC system!!!!! CC pumps have a stroke control valve built into pump and the ones I've seen/repaired are piston pumps. Most OC pumps I've seen are gear pumps although there are exceptions. Hyd control valves can be teed into CC systems while control valves must be attached in series on OC systems. A lot of the older CC control valves have no built in relief valves and if attached to OC system will CRACK/SPLIT the OC pump. OC valve installed on a CC system will cause excessive heat & poor performance.
I wholeheartedly agree that ALL of the components have to be selected properly to come up with a good functioning system and the correct components start with the CORRECT PUMP.
Jim,
You are just puting up a "straw man's" argument at this point. Nobody is implying that you can "T" an improper valve into an existing system.
Nobody is disagreeing that a closed center system is normally supplied by a variable volume pump.
Nobody is disagreeing that a open center system is normally supplied by a fixed volume pump.
Everyone would agree that if you put a closed center valve in front of a gear pump without a relief, the pump is probably going to come apart.
We all know that a CC system has the valves plumbed in parallel.
We all know that a OC system has the valves plumbed in series.
We agree that the proper valve AND the proper pump has to be used to meet the system design intent.
Now that we have the diversionary straw man's points out of the way, I would like to make these statements (again):
1) The term "OPEN CENTER" refers to what the VALVE does in it's CENTER position. Such a valve would have an open loop from the "P" to the "T" (or "PB") when CENTERED.
2) The term "CLOSED CENTER" refers to what the VALVE does in it's CENTER position. Such a valve would have the "P" port blocked when CENTERED.
If you agree with these 2 statements, then we are in complete agreement.
There are applications where a fixed displacement gear pump is used with a closed center valve. Such a system is used on simple systems where the pump is electrically energized simultaneously with activation of the control valve. I realize that our discussion is centered around tractors, but I wanted to throw it out there, and make the point that gear pumps can be used in both applications, and piston pumps can be used in both applications.
