CurlyDave
Elite Member
I appreciate the responses to my question. Looking at it again, I think my thought did not quite come through the question I asked. Guess I should've prefaced my post with: "Following all aforementioned great advice like any intelligent tractor operator should, obeying all safety rules and limitations of the equipment in question, said equipment being properly connected, loaded and secured, and tractor operator being fully conscious, sober and alert" and then asked: Any opinion on whether the aforementioned 3-pt. hitch adapter, (steel triangle that connects to all 3 points of the 3-pt hitch and accepts a standard pick-up 2"x 2" hitch-ball mount) with said 3-pt hitch in a properly lowered position, would be any better or worse than towing with the drawbar in which a standard hitch ball does not fit properly without some sort of bushing or adaptation?
I might be a newbie, but I can use lots of words (some big ones too) in one sentence.
'Dude's avatar/advice:
LBrown: Ouch, man. Sad story. Point well taken. Carelessness, impatience, inattention, fatigue all can be stealthy enemies, wreaking havoc or worse when we least expect it.
Just go get the bushing, it is cheap.
The factory engineers have put a lot of effort into assuring that the tractor will not overturn if you pull from the drawbar.
If you pull from the 3 point hitch the tractor can overturn. Also, since there is no downpressure on the 3 point, it will automatically lift up as a hard pull tries to overturn the tractor, making the situation worse.
If you have your seatbelt and ROPS you may survive.
Your adds are a lot better using the proper drawbar.
