_RaT_
Super Member
- Joined
- Apr 19, 2000
- Messages
- 5,813
- Location
- Peoples Republic of Northern CA.
- Tractor
- Kioti 3510-SE HST
turnkey4099 said:The fireplace is called a Rumsford I think, someone else has it as Rumford. A search will probably turn it up by either version.
Never built one myself but did a _lot_ of research back when. Building one is not a DIY project unless you are an accomplished mason to beging with. From the hearth on up to at least the breast every row of brick is sloped and that slope changes several times. Lots, and I do mean _lots_ of trimming brick.
Efficiency - worst possible way to heat a room other than building a fire in an open pit in the floor. They are efficient in only one way - getting rid of wood. Even when they are out with the damper shut, they are leaking air up the chimney (unless you stuff a chunk of insulation up there).
Atmosphere - yep, that is where a fireplace shines, A jug of wine, bearskin rug, fire and thou!
Harry K
Boy isn't that the truth. When our old fireplace up at Tahoe had the old rock chimney removed by tons of snow, it was the best thing that could have happened. We put in a great "Regency" brand fireplace system. Unbelievable results.
