Opinions on Diesel Trucks???
   / Opinions on Diesel Trucks??? #121
Looks like a 4" lift. Probably used a full spring lift. Looks nice with the big tires. If you don't tow a whole lot, a strong 300 hp small block rebuild should be enough. Its easy to get that kind of power from a GM crate motor too. The towing 383 goes for around $3,700 : example
But you can do it for less with a local machine shop probably if you rebuild your own and re-use rods, crank etc. But, the price will not be much lower using the name brand parts..
Emissions shouldn't be a problem in the 3/4 ton. But, GM does make smog certified replacement motors too.
   / Opinions on Diesel Trucks??? #122
Congrats jlbota,
I just got one too! Mine is a 6spd HO DRW 4x4. I really like this thing so far. Had mine a month today. A couple of good sites that discuss these trucks are Diesel truck resource and Turbo diesel register forums.
I looked at the bigger trucks and if I wasn't going off road that would have been the way to go money wise. The Dodge was a good compromise for us. will pull the trailers and work in the pasture.
Swapping engines in chevies, is not too big a deal. We did a pickup from a straight six to a small block. Had different motor stands, but they just bolt in place of the others, same crossmember for transmission. Went from a powerglide to TH400. Fan shroud was changed also. different yoke on driveshaft for new transmission and speedometer gears. If you plan to keep the burb you can drive the money's worth out of it. I had a $2,500 truck put $2,500 into it drove it another 80,000 miles and could still get $1,500 to $2,000 for it. So the 80,000 miles cost me 3-$4000. Not bad considering what a new one costs.
Reason for buying a new one was bigger family and 4wd.
As far as insurance goes, my dad wrecked an older car and was offered a low ball settlement. Dad's car was 12yrs old but was extremely clean for its age. When they totaled it, he said fine, I will go find a car in similiar condition and you can purchase it for me. Well, Dad found a similiar car, but had more miles and fewer options than his. All of a sudden his car wasn't totaled and would be repaired.
Not all 12 year old cars are the same. So if you have major improvements to your vehicle keep receipts. It will help establish that your vehicle is not in the typical condition for that age and type of vehicle. A friend had just replaced the engine in her car and totaled it. She was given a higher settlement because of the increased value. She still didn't come out ahead, but recovered some. If you are happy with the truck otherwise, a new engine might not be a bad deal.
If you just don't want to work on it, I understand that too, been there.
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2015 MAC FLATBED 48FT TRAILER (A52141)
2015 MAC FLATBED...
2024 John Deere 872GP Articulated Motor Grader with GPS Package (A52377)
2024 John Deere...
2022 Big Tex 22GN-35BK+5MR 40ft T/A Gooseneck Equipment Trailer (A51691)
2022 Big Tex...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
