Opinions on the JD 4115
   / Opinions on the JD 4115 #1
Anonymous Poster
Epic Contributor
I have been looking at the JD 4115 at it seems to fit my needs quite nicely. That would include, yard work on about 5 + - acres and snow blowing a driveway that is about 1000 feet from beginning to end. The price was just about what I could afford to spend, and its coming with a loader, snow blower and blade. For you guys out there who already have the 4115, any opinions...good or bad?
Thanks in advance for your replies.
2flints <font color="black"> </font>
   / Opinions on the JD 4115 #2
2flints,
I spent a lot of time looking at the 4110's predecessor, the 4100, but ended up with a 4200. The clincher for me was the fact that JD does not recommend a backhoe on the 4100 or the 4115 and if you put an aftermarket hoe on it you will have warranty problems. At my age I am tired of digging with a shovel and a backhoe seemed to be a good solution. Accordingly, if you think you might want/need a backhoe you might look at the 4210, the price differential isn't that much.
Bill
   / Opinions on the JD 4115 #3
I agree with Bill, if you think there is a chance you would want a BH some day go with the 4210. I have a 4110 which I really like...BUT...if a had a "do over" I would have gone with the 4210 or a Kubota B7800...
   / Opinions on the JD 4115 #4
2flints,
I have a JD4100, which is the predecessor to yours, using it much the same way you describe, in addition to a LOT of other uses.
As the others point out, if you want a backhoe, you MIGHT want to look at a bigger tractor - but only if you're gonna be using it a lot. Remember that you can rent a backhoe many many times for just the initial cost of one. And, depending on your usage, you could put a backhoe on the 4115. As for warranty concerns, your warranty is only a year anyway - and you need to learn how to use a backhoe properly to not damage your tractor, regardless of the setup you have. A backhoe is one of the hardest workouts for a tractor - puts a lot of stress on it. I don't have a backhoe - I can't justify even building one myself. I have a neighbor with a backhoe on a JD955, and I have a set of keys to it. (He has a set of key to my tractor too.)
The thing to remember is the size of the tractor - and how appropriate is it for what you're doing with it MOST of the time. There's about 8 tractors with owners on the road I live on - and everyone of them agree that the 4100 is an exceptional tractor for what I do with it - and that's the point. The more implements you have, the more you can do with a tractor. I have more implements than you can shake a stick at, but they are all sized correctly for MY tractor. My neighbor has a 37 hp Kubota - beautiful tractor - but he also has about 55 acres. I have about 3.5, split between lawn and woods, with a large paved driveway. I do a lot of mowing, and a lot of snow throwing. Another neighbor has about 12 acres to mow - and he does it with the same of setup I have (except for a bagger).
A lot of talking there to make a point - the setup would probably work very well for you. However, keep in mind that Kubota and NH also make comparable tractors that would probably work very well too. I looked at them all, and went with the JD because they had all the implements I wanted to do what I wanted to do.
BTW, consider getting the broom for a paved driveway - especially one as big as yours. It's exceptional for cleaning off debris year around, and for cleaning off the little bit of snow left from plowing or snowblowing. I'd VERY HIGHLY recommend it. It fits on the front quick-tatch, like the snowblower and blade. (I have all three.) Also, for the snowblower, consider getting the hydraulic chute rotation and the remote chute cap control - VERY useful when snowblowing, cause they allow you to change the direction you're blowing without getting off the tractor.
Let me know if I can answer any other questions for you.
Caretaker
   / Opinions on the JD 4115 #5
I have owned a 4115 for 10 months and have been pleasantly surprised with its capability. I wanted a CUT w/turf tires to be able to mow a 2/3 of an acre lawn and NOT leave tracks. The 4115 weighs approx. 1800 lbs not including the deck. If you step up to a 4200/4210 you'll add 800-900 lbs. I have at times desired a JD backhoe, but the cost ($6000+) was the deciding factor. I'll rent one when I need one. The 4115 w/61" FEL, 60"MMM, 60"Box Blade, and ballast box have worked beautifully. Unless you need a backhoe, you'll find the 4115 a great machine.
Steve
ps - If Deere decides to make a small backhoe for the 4100/4010/4110/4115, I'll probably get it. /forums/images/graemlins/grin.gif
   / Opinions on the JD 4115 #6
I heard they are coming out with a model 46 backhoe in August for the 4115. List price around $5800.
   / Opinions on the JD 4115 #7
Like "Caretaker", I own a 4100 Hydro for my 2.1 acres
and love it, but like "JDGREEN4ME", if I had to do it
all over again, I would have got a 4200/4210, simply
because they are far more comfortable tractors because
of the seat and operator platform. If it was me, I would
skip the 4115 and either get a 4110 or a 4210 depending
on the weight requirement for the tractor. The 4100/4110
has plenty of power for it's size, so I view the increase in
money and power in the 4115 as a potential waste of money.
However, I think all of the 4XXX machines are nice quality.
From what I have read, 4115 owners love their tractors.
KUBOTA BX2350D TRACTOR (A51247)
KUBOTA BX2350D...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A52748)
2014 Dodge Ram...
378745 (A51573)
378745 (A51573)
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A52748)
2003 International...
