Snowblower Opinions re JRW Snowblowers ??
   / Opinions re JRW Snowblowers ?? #11
The shearbolt on the PTO shaft protects the gearbox, this is the one that normally breaks first if you try to move something that is not white and fluffy. There is a shearbolt that goes thru the blower and the blower shaft that protects the blower. The auger is protected by a shearbolt just inboard from the smaller chain sprocket, you can just barely see it in your picture. Attached is a picture of a blue JRW with the big half-moon chute turning device that comes from JRW, minus the hydralic cylinder.. Mine came with the device, but I just made my own...black blower picture.
   / Opinions re JRW Snowblowers ?? #12
My flighting on my auger is made from a one piece spiraled 1/2" X 1 1/2" cold rolled, and yours might just be an older design with the end flighting welded on. Probably just a bad weld and you can fix it up better than new. The augers do little work other than gather the snow, they get most of their abuse from backing into trees/rocks/etc... I would spend some extra time cleaning up the inside of the chute and inside the blower area. Get them as smooth as posibile and put on a freash coat of paint. During the winter, the paint will disappear some, and the metal will get polished from all the rocks and sand you pick up. A fresh coat of paint each spring keeps these areas ready for the snow the next winter...
I take my chute off each spring and apply a fresh coat of white lithum grease....a little lube on the chain and shes ready....... Have fun...I have a feeling we are going to be using our snow removal equipment LOTS this winter.....
Thanks Guys for Information...
Jerry....with the hydraulic contraption on the blue blower, does it still use cables or is there some sort of worm gear similar to the pics that Scooby posted?? I wonder if JRW still has any spare parts kicking around? Eric
   / Opinions re JRW Snowblowers ?? #14
The stock contraption is a 'D' shaped thing that mounts where the tapped plate is, and the 'D' faces away from the chute. A hydralic cylinder can be dropped onto the contraption, one end on the 'peg' your picture shows by the chute, and the other end on a peg on the 'D'. Cables go around the chute and around the outside of the 'D', which is made of rolled channel so the cable won't fall off the outside of the 'D'. It is a pretty simple setup, but I would think that any setup off any brand blower chute could be modified to work for you. You can spin the chutes around manually real easy, so it would not have to be much of a cylinder. Even an electric setup or hydralic motor would be worth looking into.... Good luck !!
PS: 'Contraption' is a great name for it...!!!!
Jerry...
Definition for Contraption here is "something that looks neat but no idea what it is called" LOL
   / Opinions re JRW Snowblowers ?? #16
Are they still in business? My dealer is installing a hydraulic chute for the JRW 60" I bought from them 4 years ago and he said that JRW is out of business. Anyone else heard this?
RFMR...
Seems like they have folded up shop, too bad
I sure would love to see some pics of the dealer installed hydraulics, please, please
Eric
   / Opinions re JRW Snowblowers ?? #18
When I get it back I'll post a picture.
   / Opinions re JRW Snowblowers ?? #19
The following is for your info on JRW...... I think they got in trouble for not having a permit for their painting operation...most shops have to have air quality permits for enviromental reasons... eh? Couldn't afford to spend all those loonies to build an up to date paint booth.....
Court Bulletin For immediate release
September 5, 2008
JRW ENTERPRISES INC. FINED $5,000 FOR FAILING TO COMPLY WITH A PROVINCIAL OFFICER ORDER
SIMCOE JRW Enterprises Inc. has been convicted of failing to comply with a Provincial Officer Order by failing to apply for an air Certificate of Approval for its metal parts fabricating business in Norfolk County which makes equipment for the farming industry. JRW Enterprises Inc. was charged following an investigation by the Ministry of the Environmentç—´ Investigations and Enforcement Branch. Notwithstanding that the company is now a bankrupt corporation, it was fined $5,000 plus a victim fine surcharge, and given 30 days to pay.
-30-
For further information:
Members of the media:
John Steele
Communications Branch
(416) 314-6666
Contact information for the general public:
416-325-4000 or 1-800-565-4923/
www.ontario.ca/environment
   / Opinions re JRW Snowblowers ?? #20
Hi all - I have one the Erskine 6' frontmount snowblower attachments on my JD4500. What Erskine has done to help prevent snow from clogging inside the shute is line it with a piece teflon. It's about an eighth inch thick and held in place with rivets. It will wear over time but very easy to change out for a new one. Plus, they are easy to fabricate if you have access to a sheet of it. Roger
2024 INDUSTRIAL  MINI EXCAVATOR (A58216)
2024 INDUSTRIAL...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
2018 New Holland C227 Compact Track Loader (A56438)
2018 New Holland...
2005 KOMATSU GALEO D39PX-21 CRAWLER DOZER (A52709)
2005 KOMATSU GALEO...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A56858)
2013 International...
