Orange Tractor & Green Grass!!
   / Orange Tractor & Green Grass!! #1
Glowplug
Veteran Member
3rd Planet from the Sun
Kubota M7040HD
Got to do some mowing with the m7040 and new Rhino 10' rotary cutter this weekend! Man, what a blast. Took a little while to level up the mower deck, since it hasn't been used yet. I took off the front-end loader to mow. That was incredibly easy! It only took a few minutes. I was worried that I would never have the nerve, or patience, to take the FEL off. But it couldn't have been easier. Now, I just hope I can reattach it!!:eek:
Here's another interesting photo!
   / Orange Tractor & Green Grass!! #3
Good to see you are really enjoying the beast glowplug.
   / Orange Tractor & Green Grass!! #5
Wouldn't you want the FEL for front ballast? That mower has to weigh a ton.
   / Orange Tractor & Green Grass!! #6
Looking good. Our grass is still brown.:D
Did you mark your hoses for reattachment?:D
   / Orange Tractor & Green Grass!! #7
It looks like the mower is riding on the rear wheels when in use.
The FEL kinda gets in the way. It does give better ballast. But it makes trimming in the tight fence corners difficult. It also makes visualization much, much better without it. The mower is a pull-type mower, not a 3ph lift type. It does make the front-end light. I would like to find a way to get some Front-end weights to use in such situations when the loader is off.
Don't have to. I have the hydraulic multi-coupler. All you do is move one lever and all the hoses are released in one block. To reconnect them you just slide that block back into place and lock it with the lever.
   / Orange Tractor & Green Grass!! #9
Nice outfit! Both machines count on that! We haven't turned green yet as the snow banks are finally down enough we can see the plow damage and the spring work needed to get into the yards! Good Luck!
2012 Dodge Charger Sedan (A44572)
2012 Dodge Charger...
50ft Fuel Line (A44391)
50ft Fuel Line...
2025 Ford E-450 Super Duty Van, VIN # 1FC4E4KN3SDD00016 (A44391)
2025 Ford E-450...
Tag-A-Long Trailer (A44571)
Tag-A-Long Trailer...
2015 Ford Explorer AWD SUV (A44572)
2015 Ford Explorer...
(1) HD 12ft 6in Panel (A44391)
(1) HD 12ft 6in...
