Ordered a Markem tooth bar today
   / Ordered a Markem tooth bar today #11
SnowRidge said:
They go to great lengths to tell you to measure carefully, and they provide instructions on just how they want you to measure, and then build the bar as if you were an idiot and can't follow simple insructions? To me that is an unacceptable business practice.
They tell you they will build it to fit, and they do otherwise.
I agree....if you tell them 65 inches and it don't fit...then you should have to pay to get it fixed. But they should make it what you tell them. In Snowridges case, he should have the option of returning it because it wasn't what he ordered. Although shimming was probably much less hassle than the return.:rolleyes:
   / Ordered a Markem tooth bar today #12
It Say's right on the website they use your measurement minus 1/4":
Markham Welding
   / Ordered a Markem tooth bar today #13
Exactly. It works well, too.
   / Ordered a Markem tooth bar today #15
SnowRidge said:
It was a lot more than 1/4".
Maybe you should call your lawyer:D
I am bowing out of this debate...
   / Ordered a Markem tooth bar today #16
Markham Welding
Well, I reckon that's different...:rolleyes: So you should measure, then add 1/4in so they can take it off. As long as everyone knows what everyone else is doing:p
   / Ordered a Markem tooth bar today #17
TC29-dude said:
It's slotted and intended to be flipped up out of the way. I will have to see how that works out.
As far as unbolting...I was thinking of using pins similiar to the ones on the ROPS to make it an easy on/off attachment. More than likely it will go on and never come off.
I was happy with the price, $273.00 shipped. I was expecting to spend close to $400.
Make sure you drill the holes at the front of the slot so just loosen the bolts and pull forward and flip it up out of the way.
   / Ordered a Markem tooth bar today #18
Naw. I am not like the TBN member who sent his back because one of the teeth was on a little crooked, and when he got it back, he took it to the body shop to have it professionaly painted shiny automotive black. :eek:
Debate? What debate? No candidates here. :rolleyes:
BUSH HOG 74" ROTARY TILLER (A57192)
BUSH HOG 74"...
QUINCY INDUSTRIAL AIR COMPRESSOR (A52706)
QUINCY INDUSTRIAL...
2012 Ford Econoline Cargo Van (A56858)
2012 Ford...
2017 Ford T350 Van (A55973)
2017 Ford T350 Van...
2010 Ford F-450 16ft Box Truck (A55852)
2010 Ford F-450...
UNUSED FUTURE HYD MINI AUGER (A57193)
UNUSED FUTURE HYD...
