Other uses for cultivators
   / Other uses for cultivators #1
Haywire
Veteran Member
Central Kentucky
Tractorless :(
What do you use your cultivator for other than cultivating?
Ian
   / Other uses for cultivators #2
When not in use as a cultivator....I removed the two centers and built a disc hller to add(used to make raised beds) works well.I purchased all the parts from Agrisupply....a little welding involved.
I saw that EA offered a hiller attachment for one of their cultivators... pricey though. How much did you have in your version?
   / Other uses for cultivators #4
After searching for a section or two of old C tine drag at farm auctions, I gave up and now just use the cultivator. It is almost as good, and by being on the 3 pt instead of on a chain being pulled, it works very well.
If I could pick up some Danish, one sided sweeps for the center, it might work good for throwing dirt up on potatoes. Some have tried it and like it.
   / Other uses for cultivators #5
That KK 1 row cult makes a fine 2 row laying off plow for making garden rows. Just remove the inner 4 shanks and wrap a grass sack around the outside 2 shanks. A 2 row cultivator will do excellent for a 3 row laying off plow. Ken Sweet
   / Other uses for cultivators #6
I remove the sheilds and 4 of the shanks from my Dearborn 13-2 springshank. Evenly space out the remaining shanks, it's like a miniature chisel plow on various plots I've got rye cover on. I can sink it pretty deep, busts up the ground prior to seed bed prep. Works good. :thumbsup: Mark
Utility Trailer (A52377)
Utility Trailer...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
2016 Ford F-450 12FT Flatbed Truck (A51692)
2016 Ford F-450...
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
2015 Ford F-550 Altec AT40M 40ft Insulated Material Handling Bucket Truck (A55788)
2015 Ford F-550...
