Other uses for cultivators
   / Other uses for cultivators #1
Haywire
Central Kentucky
Tractorless :(
What do you use your cultivator for other than cultivating?
Ian
   / Other uses for cultivators #2
When not in use as a cultivator....I removed the two centers and built a disc hller to add(used to make raised beds) works well.I purchased all the parts from Agrisupply....a little welding involved.
I saw that EA offered a hiller attachment for one of their cultivators... pricey though. How much did you have in your version?
   / Other uses for cultivators #4
After searching for a section or two of old C tine drag at farm auctions, I gave up and now just use the cultivator. It is almost as good, and by being on the 3 pt instead of on a chain being pulled, it works very well.
If I could pick up some Danish, one sided sweeps for the center, it might work good for throwing dirt up on potatoes. Some have tried it and like it.
   / Other uses for cultivators #5
That KK 1 row cult makes a fine 2 row laying off plow for making garden rows. Just remove the inner 4 shanks and wrap a grass sack around the outside 2 shanks. A 2 row cultivator will do excellent for a 3 row laying off plow. Ken Sweet
   / Other uses for cultivators #6
I remove the sheilds and 4 of the shanks from my Dearborn 13-2 springshank. Evenly space out the remaining shanks, it's like a miniature chisel plow on various plots I've got rye cover on. I can sink it pretty deep, busts up the ground prior to seed bed prep. Works good. :thumbsup: Mark
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
2010 Ford Transit Connect Cargo Van (A53422)
2010 Ford Transit...
2017 Ford F-150 Crew Cab Pickup Truck (A54814)
2017 Ford F-150...
Hesston PT-7 Haybine (A50775)
Hesston PT-7...
2015 MACK CHU (PINNACLE) TRI AXLE(INOPERABLE) (A55745)
2015 MACK CHU...
EXCAVATOR GRAPPLE (A53843)
EXCAVATOR GRAPPLE...
