BufordBoone
Platinum Member
Ran thru my first spool of flux core wire (faster than I expected) in my Lincoln 210 MP.
Realized that there was a long tail of wire I had to waste. Didn't know if I could just pull it a little way in and then start the new spool or had to pull it all out and waste it.
Not wanting to chance messing up my machine, I pulled it out and threw it away, restarted a new roll and went back to practicing.
What says the community? When you run out of wire, do you waste what's in the gun or is there an acceptable way to use it up?
Edited to add: I was using 1 lb spools. I plan to go to larger spools to solve some of the problem. I think my machine handles 1 lb or 10 lb. Will look it up when I get home.
