turnkey4099
Elite Member
I got my first one at Wal Mart. Under $20. It is still working and batteries last about 2 years.
Harry K
Harry K
My unit is a la crosse and according to their website the battery in the outdoor unit should last about a year. So I suspect their is something wrong with the unit. I was tempted to try Lithium batteries which would be better, but didn't want to throw money away if that wasn't the problem.
I have another outdoor unit that I am not using, so maybe I will test it out to see if the batteries last longer.
I have a couple of solar yard lights and will have to check into it to see if I can get it to work with my outdoor unit.
If not, I think I will look at some of the recommendations here for a new unit.
Thanks
Wes
I also have a Lacrosse unit and I just changed batteries last week. It been up on the porch for over 2 years. I had a WeatherChannel brand in Canada and a set of batteries would last at least a year even in the -40C temps up there. I dont think mine transmit continuously but about every 10 minutes it sends a signal because it took that long or longer for the house unit to pick up the signal when I changed the batteries. Yours must be sending constantly to burn batteries like you describe.i have a LA Crosse unit and only change batteries twice a year,even in sub zero weather.
Are you using Lithium Batteries? Not only do they last much longer but are also not as negitively affected by temperture changes.
