k0ua
Epic Contributor
check with the local Ham Radio club. They quite often have members that are willing to help with something like this.
Good idea, that tower looks like an old Rohn 6 or one of the older Nello towers. they were not all that strong to begin with. but if in good shape and not rusted out at the bottom or split from freezing water, it is climbable. if you could find someone to climb it with a proper belt, and rope and hopefully a gin-pole. If it has old worn out 300 ohm twin-lead, a new run of rg6 coax and balun at the top might be a good idea. if the run would not be too long. As long as the antenna is in good shape it would probably work fine. As old and fat as I am I would probably climb it if it was safe, but I have climbed a lot of them thru the years. but my tower is a Rohn 25, with much safer criss-cross bracing, and it tilts over now. But as others have said, you need the proper safety equipment, and no fear, as well as the sense to check out the tower for strength. Get Ham help if you can or professional 2 way radio installer. Sometimes you can find a contact for the local Ham club in the phone book. Or if you want to search for a local contact go to QRZ.com (Ham database) and search in your city, and start crossing the names with the phone book and start calling for help, if you are persistant you can find them. If you fall from 30 feet, you are most likely either dead or badly injured.
James K0UA
