Outdoor wood boilers
   / Outdoor wood boilers #11
Re: Outdoor wood boilers
BTW, mine is a stainless steel firebox, and a dual fuel unit. If you dont go dual fuel then you have to have a backup in the house, or never leave home in the winter.
Ther drier the wood, the less smoke and the longer the burn time. When you first fill it and the damper opens, it will smoke a lot. When the damper shuts, it will choke down to just a wisp because the air is cut off and it goes to a smolder. Once the moisture is out of the wood it will blow a nice blue smoke when the damper opens.
You can burn anything in them, but cured dry wood makes more heat per pound.
In cold weather I mostly have to fill it in the morning and after supper. When it is like it is now, it depends. Once a day when its 60 in the day and 30 at night. If the temp is 70 in the day and high 40's at night, it will go a day and a half 2 days. I mostly cut off the heat exchanger for the upstairs when its warm, because the radient heat in the basement floor holds the upstairs of the house at around 70. That increases my burn time because the heat is not bleeding into the ductwork.
If you do get one, insulate the incoming pipes and the manifolds if you go radient. Keeping the heat in the pipes will increase your burn time, and let your zones work. If you dont insulate the incoming pipes and the manifolds then you will leech heat into wherever the pipe comes in, making it HOT and increasing your wood usage. I posted pics before of the manifold and pipes coming in, I'll see if I can find then, or I'll just post them again.
Varmintmist
With radiant floor heating how do you cool your home?
Or do you not use AC?
   / Outdoor wood boilers #13
Open the windows /forums/images/graemlins/grin.gif and ceiling fans.
The upstairs is forced hot air with a heat exchanger in the plenum. There is a spot for an A coil if I decide to add AC. That is why I went with forced hot air in the upstairs. The basement could be cooled if needed by installing a register or two in the duct. The basement is about 50% underground, so the temp shouldn't get real high there in any case.
Thanks,
I was afraid that I could not add AC with the wood boiler heat exchanger(plenum?) in place.
We are considering a modular home with a FA system as part of the package. This could be held but doesn't lower the price much.
   / Outdoor wood boilers #15
Thats what we put up. A modular ranch with forced hot air. The thing is, what you save in plumbing with hot water, you spend on duct work for the air.
Where in West by God do you live?? My folks are down in Kenna, off 77, 45 min north of Charleston.
   / Outdoor wood boilers #16
We have a Hardy Manufacturing outdoor wood furnace, it was on our property when we bought it. It took a bit of fixing to get it working, which seemed to be install issues, but now it works like a charm. When the indoor thermostat calls for heat the hot water is pumped to a heat exchanger in the plenum of our central ac/furnace and the fan blows the hot air thru the house.
Like others have mentioned it produces some smoke when heating the water but when dampered you rarely see a wisp of smoke come out.
- Tim
Located in North Central WV, about 30 minutes NE of I-79 exit 119. I will be within 30 miles of Kenna tomorrow traveling for work.
Thanks TW,
I looked into the Hardy brand but they don't have dealers outside your area.
   / Outdoor wood boilers #18
I have a Taylor outdoor wood burner that I have had for over 10 years, and I have never had any problems with it. We had it at our previous home and when we sold the house the people who bought it did not want to bother with cutting wood so we moved it to our new modular ranch house. We have radiant heat in the basement and cast iron hot water baseboard on the main floor. I figure I usually burn about 6 or 7 cord a year. I usually fill it once a day at supper time unless it is real cold out, below 15 degrees for the daytime high. In the summer I usually fire it up once a week to heat the domestic hot water in the house.
Ernemats,
That's great to hear, information like this is leading to this decision more all the time.
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
2020 Peterbilt 520 T/A Cab and Chassis Truck (A51692)
2020 Peterbilt 520...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
