Outrageous Kubota part price increase
   / Outrageous Kubota part price increase #21
We are on it, and they are aware. There is some stuff that makes absolutely no sense. We found a label that went from like $3 to over $40. I don't expect it to stay this way.
   / Outrageous Kubota part price increase #22
You are a great resource for the forum and Kubota owners...
Sometimes glitches happen and go undiscovered until questioned.
   / Outrageous Kubota part price increase #23
Another comment on the anti-seize compound.
>Yes, it somehow gets into and onto everything. It is even worse than black grease for "how did I get it there?" situations.
>I once put anti-seize (silver compound) on my truck's wheel lugs. The tire dealer had an absolute fit when I went in for a free rotation. He spent quite some time, and a lot of solvent, getting it off. His claim was that lug nuts need friction and even a little corrosion to remain seated and tight.
>I still use it on bushhog blade nuts and bolts. It is far more expensive than grease and seems to work the same. :confused2: The huge nuts still come off easily with a quality impact wrench. Just my thing.
   / Outrageous Kubota part price increase #24
Amount of anti seize needed is a tiny brush swipe. It's not an entire coating or a big dollop. It should be hard to tell it's been added after things have been assembled and then the subsequent disassembly. I use it regularly and have the same small bottle (1/2 pint or so) I've had for the last decade.
It comes off with the same type stuff you remove grease with.
   / Outrageous Kubota part price increase #25
Funny thing. Loctite properly applied also functions as antiseize...
Keeps things from loosening and from seizing as well.
   / Outrageous Kubota part price increase #26
Never had a never seized nut or stud come loose. I use it on all my wheel studs.
   / Outrageous Kubota part price increase #27
Use high temp anti-seize on injector and spark plug threads for easier removal.
   / Outrageous Kubota part price increase #28
For spark plugs, I have some 50 year old Champion spark plug anti-seize... graphite in some sort of hi temp oil. Came from the aircraft industry, where aluminum cylinder heads and steel spark plugs have to not seize- never, no how .
   / Outrageous Kubota part price increase #29
Anti seize is merely a chemical to prevent galvanic corrosion form sticking metals together. It has negligible effect on torque.
   / Outrageous Kubota part price increase #30
What about the part price increase?
DIRT DOG BBX72 72" BOX BLADE (A57192)
DIRT DOG BBX72 72"...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
12 ft Shipping Container (A55973)
12 ft Shipping...
2004 Sterling Acterra Cab and Chassis S/A Truck (A55852)
2004 Sterling...
20' Shipping Container (A56469)
20' Shipping...
