Over running coupler
   / Over running coupler #1
BWSwede
Washington
Yanmar
I am currently running a rear mount snowblower on the front of my tractor. Because the front PTO spins the reverse direction from standard I am having a hard time finding an over running coupler to smooth out my operation.
I am thinking a taking a standard over running coupler and with a couple adapters installing it backwards on my front PTO. By doing this the coupler should free wheel as designed. My question is whether or not these devises can handle the power being input onto their output shaft (male end) and output onto their input shaft (female end).
Has anyone ever done this or taken one of these things apart to see how they work?
TIA,
Blane
   / Over running coupler #2
TIA,
Blane
Ive never taken one apart...but you shouldn't even need it for a snow blower. I use one for my mower and for my chipper/shreader as they continue to spin after disengaged. A snowblower will stop nearly immediately when clutch is pulled....mine always have
GRS:
You're right. You normally wouldn't need one but I reversed the PTO input direction on the snowblower by using a loop of #80 chain. When I back off the throttle I am getting a little more chain slap than I would like when the fan bounces back and forth within the slack in the chain.
Thank you,
Blane
   / Over running coupler #4
GRS:
Thank you,
Blane
oh.. i see. I tries looking up a counter-clockwise and a clockwise overrunnung clutch and i only see them for standard direction.
   / Over running coupler #5
I have always thought that most have a simple set of hinged dogs inside.
Since these dogs are just spring loaded straps of metal that end up being compressed (force is applied to both ends), I wouldn't think it would matter which side the power was coming from- they ought to hold it.
KYErik,
Thank you. I sort of thought it was something like that. I'll give it a shot and see what happens.
Blane
2018 CATERPILLAR 320GC EXCAVATOR (A51242)
2018 CATERPILLAR...
1996 PETERBILT 357 35 TON WRECKER (A50505)
1996 PETERBILT 357...
2008 Ford F-350 Altec Service Truck (A50323)
2008 Ford F-350...
John Deer 625F Grain Platform (A50514)
John Deer 625F...
2011 CATERPILLAR D9T HI-TRACK CRAWLER DOZER (A51242)
2011 CATERPILLAR...
Unused Delta Crash...
