Sad to say I have an update on overheating "solution". Two days ago it was 88 degrees (hot for VT) and I decided to try pushing the Robin by finish mowing a half acre field that had grown up to about a foot deep of thick hay grass. I went slow to not bog the engine and get a good cut, but about an hour into the job the engine shut down, overheated, and wouldn't restart until after an hour+ cool down. Interesting that the overheating was NOT due to the temperature wire/FI computer shutting down the fuel pump as before (still power to the pump and it was running), but something else, I suspect maybe vapor lock?? Lots of bubbling in the fuel filter and before shutting down the engine cuts out then surges a few times before shutting down completely.
Last Fall I cut the same field and also another half-acre field with the brush mower in one swoop also in 80 degree weather, with even taller grass, but could not push the engine to overheat. So I assumed my fix was invincible.
Oh good, another problem to solve! Or at least I can promise to be smarter by choosing the right implement for the job at hand (never finish mow tall grass) and taking a break every now and then.
The exhaust manifold bolts are tight. What else could have changed?
I am realizing that the CFMs of the fan seem about half what they were last Fall when the fan was like a tornado and kept the engine cool. I am going to take it apart today to clean/lube if possible, but if that doesn't help I will explore another fan manufacturer with a stellar reputation for long life and more waterproof (perhaps SPAL, which means I would have to change to a larger fan).
