Overriding Couplers and Slip Clutches
   / Overriding Couplers and Slip Clutches #1
rfawkes
Illinois
Kioti LK3054
After just replacing power take off bearings in my tractor for hitting a rock which stopped my tiller, I started looking for something that would prevent this ever happening again. I see both clutches and couplers on sale at TSC, but I don't know how they work or how to attach them or which one I should use. Any help you can provide would be appreciated.
   / Overriding Couplers and Slip Clutches #2
To prevent such damage if the tiller is stopped by a rock or root you need the slip clutch.
   / Overriding Couplers and Slip Clutches #3
I've had this same basic question - I know what the slip clutch is/does, but what does the overriding coupler do?
Doug /forums/images/graemlins/confused.gif
   / Overriding Couplers and Slip Clutches #4
Don't they let the implement spin down gracefully when the engine slows abruptly?
   / Overriding Couplers and Slip Clutches #5
Tim that exactly what they do. If you have a rotary cutter spinning at full RPMs and you shut down the PTO, instead of the rotary cutter transferring all that kinetic energy back into the now stopped PTO the overriding clutch allows the mower to stop slowly and without undue stress to the tractor.
Thanks for the information. Now, how do you install the slip clutch?
   / Overriding Couplers and Slip Clutches #8
Rfawkes typically a slip clutch is bolted to the gearbox (see my picture of a tiller) then the implement PTO shaft is attached to the slip clutch. If you are adding one most likely your original PTO shaft on the implement will need to be shortened somewhat.
   / Overriding Couplers and Slip Clutches #9
Do I need an overiding clutch for my finish mower? I have some ground level stumps that I nick a bit. I'd hate to think that it could somehow mess up my tractor
   / Overriding Couplers and Slip Clutches #10
That is a decision you have to make. The bottom line is that if you hit something that stops the blade, something has to give. The blade, the gearbox, the shear pin, the PTO.......something will give. A slip clutch is designed to give in that situation to save other components.
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A52576)
2014 HINO 338 26FT...
2012 Caterpillar AT1055E Track Asphalt Paver (A51691)
2012 Caterpillar...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A52748)
2014 Dodge Ram...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2014 ATC TRAILER (A52472)
2014 ATC TRAILER...
