W5FL
Veteran Member
- Joined
- Apr 7, 2000
- Messages
- 1,558
- Location
- Central Texas
- Tractor
- TYM T-1104/TX10 Loader Kubota M6800SD/LA1002 Loader Kubota RTV900
When I first built this fence, I used a rust converter that went on clear (or white) and dried to a black color over a few days originally and then put a second coat of acrylic green paint over that. That seemed to work well. /w3tcompact/icons/smile.gif
After about 5 years, the rust is coming through the paint heavy at the top (sunshine, I guess) and the entire pipe fence needs to be repainted. /w3tcompact/icons/frown.gif
The fence is also covered with a 2x4 no climb horse wire mesh, so the paint will have to be sprayed.
I have a heavy duty airless powered by a 5000Watt Generator, but all I can get from paint companies is that their paint is better than anyone else.
Tractor Supply also has everything from an asphalt based paint ot tractor implement paint (expensive) but has no idea how well they work.
I have found a Jones Blair paint in 5 gallon containers $75.35 per 5 gallon bucket for their Rust-Not in a Gloss Black.
Any suggestions appreciated for long lasting paint for use in painting this fence. I cannot remove the fence material to paint the 2 3/8 pipe posts and top rail, so not much preparation is possible. Prefer a one coat spray application product as there are 4000 linear feet to paint.
