PBinWA
Platinum Member
- Joined
- Jun 10, 2004
- Messages
- 893
- Location
- WA
- Tractor
- Kioti NX55, Mahindra 2615, Case 36CXB, Case W4, Volvo MC85C
RalphVa said:I don't know what that POR stuff is. What you need to apply, after first wire brushing the loose stuff off, is one of those treatments that turn the rust (iron oxide) into black iron sulfide. Rustoleum makes one called Rust Reformer. NAPA makes one. Trustan is one of the old brands. I've poured Trustan into one of those little pump sprayers and applied it that way.
Then spray on your primer. Then your top coat. Actually, you could just stop with the Rust Reformer or Trustan. It'll protect the implement. I once put Rust Reformer on a snow plow on areas where the paint had been rubbed off. Those areas that had a tad of rust were turned black; the rest stayed apparently shiney bare metal.
Ralph
I'll second this recommendation (specifically the rust converters). Once you get a good base coat on then you can just spray bomb them every year. I watch for Rustoleum on sale and bomb everything in the fall. It's quick and easy and works good enough for me.
