Painting Pressure Treated Lumber
   / Painting Pressure Treated Lumber #11
I've been told you're not supposed to paint pressure treated lumber. I don't always follow the rules though. I use an oil based primer after the wood is thoroughly dry, then a good outdoor paint. I've used latex on top of the oil base with no problems.
I hope your luck is as good as mine.
Tom
   / Painting Pressure Treated Lumber #12
</font><font color="blue" class="small">( Can you put an Oil Based Paint over a Latex Primer ? )</font>
No. (Although if indoor paint you can probably get away with it.)
Cliff
   / Painting Pressure Treated Lumber #13
Thanks Cliff, "GOT IT" !!!
I was always confused on that, appreciate it!
Sorry Shimon if I hijacked the thread.
   / Painting Pressure Treated Lumber #14
My understanding is that you can use latex over oil, but not oil over latex.
Lowes carries a water based primer that says on the can it can be used on PT primer. A friend used it a couple of weeks ago and it looks ok, but two weeks isn't much of a test.
2024 John Deere 872GP Articulated Motor Grader with GPS Package (A52377)
2024 John Deere...
Hydraulic Power Unit S/A Towable Pump (A53421)
Hydraulic Power...
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 JOHN DEERE...
FIRESTONE 9.5L-15 4 RIB TIRES (NEW CONDITION) (A55301)
FIRESTONE 9.5L-15...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A55218)
Galvanized...
