Pallet forks on your FEL
   / Pallet forks on your FEL #11
Justin,
I have a 4310 and bought clamp-ons. I did quite a bit of research and there are a couple of quick attach brands that hook up nicely to the arms after removing the bucket. I didn't go that route for 2 reasons:
1. Fork bending seems to be an issue with the 2 brands of quick attach units I found that will attach to my JD430. The clamp-ons I got were from a company in Colorado (whose name escapes me but I am sure I can find them again). Each fork weighs in at over 90lbs and are 1 1/2 inches thick - solid steel. I didn't care for the tubular design many of the clamp-on manufacturers sell.
2. Storage was an issue for me. I have room to easily store clamp-ons but a quick attach unit would have to be left outdoors in the N.E. weather.
I think a quick-attach gives you more leverage and you can definitely see the load better than trying to look over the bucket, BUT how much can your tractors FEL lift? Leverage might not be an issue.
If I were going to use the forks alot, I would have bought the quick attach, storage or not. So far, I have used the clamp-ons twice and they worked exceedingly well. Best of all, when I took them back off, they store nicely along the wall of my garage where I am not tripping over them.
Steve Z
   / Pallet forks on your FEL #12
Would like to see some pictures of the one you made..Thanks
   / Pallet forks on your FEL #13
</font><font color="blue" class="small">( Would like to see some pictures of the one you made..Thanks )</font>
Click HERE for a post I made a while ago with pictures.
   / Pallet forks on your FEL #14
Great pictures..Exactly what I was looking for..Made my own set of QA brackets, just need to build frame to mount forks on..Thanks again..
   / Pallet forks on your FEL #15
</font><font color="blue" class="small">( Made my own set of QA brackets, just need to build frame to mount forks on..Thanks again.. )</font>
Just so you know, the brackets and pins are available from JDParts for about $35.00 or so...
   / Pallet forks on your FEL #16
I checked on them a while back..The brackets were $40 each & pins were $6 or $7 each..Decided to make my own..They look good, hope they will carry the load..
   / Pallet forks on your FEL #17
</font><font color="blue" class="small">( I checked on them a while back..The brackets were $40 each & pins were $6 or $7 each..Decided to make my own..They look good, hope they will carry the load.. )</font>
Well, I just checked JDParts, and here is what I found:
W43359 HOOK, BUCKET ADD 10.73 USD 21.46 USD
W47211 PIN, BUCKET ADD 6.33 USD 12.66 USD
And here is a POST from a while ago where I listed the part #'s and prices, they have inceased a little but not what you found /forums/images/graemlins/shocked.gif, maybe you looked at the wrong part?
   / Pallet forks on your FEL #18
Prices were from dealer where I purchased the tractor..Will give JDParts a look..My 5205 takes the 522 loader..The part# is on the bracket for the bucket..Thanks for the info..
   / Pallet forks on your FEL #19
</font><font color="blue" class="small">( My 5205 takes the 522 loader..)</font>
That could be the differance, I was unaware what tractor/loader you had /forums/images/graemlins/confused.gif
You should update your profile /forums/images/graemlins/wink.gif
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
2008 CAT D4K XL (A58214)
2008 CAT D4K XL...
2024 JOHN DEERE 50 P-TIER EXCAVATOR (A52709)
2024 JOHN DEERE 50...
2008 Featherlite Portable Office Command Center T/A Trailer with Wacker Neuson G50 Towable Genera... (A56858)
2008 Featherlite...
2017 Mitsubishi Mirage G4 Sedan (A56859)
2017 Mitsubishi...
New Holland WorkMaster 37 (A53317)
New Holland...
