"Parent Bore" vs. sleeved engines
   / "Parent Bore" vs. sleeved engines #11
I've rebuilt and repaired alot of car engines - wet sleeved and no sleeve. Bottom line is that if there is a piston sleeve I'll put new piston, rings and sleeves in and if no sleeve then it's more time and money to do it right - by stripping the block down and taking it to the machine shop for re-boring. If the car is not worth the effort then it does not get done. It just gets new pistons and rings or possibly just rings and cylinder honing. You live with the potential issues of oil consumption, lower than optimal compression, shorter engine life, etc.
   / "Parent Bore" vs. sleeved engines #12
gemini5362 said:
I am not sure what you are talking about. If you are talking about tractor engines I do not know enough to talk about it. IF you are talking engines in general. I believe that todays engines have a lot longer life span than those of the 60s and 70s It used to be that a car engine with 100,000 miles was an egnine that you planned on rebuilding pretty soon. My 1998 chevrolet tracker has 150,000 miles on it and I am expecting an easy 200,000 this is a vehicle that was sold as an inexpensive little fun vehicle.
Hmm.. I think you probably will have to narrow that 'engine' range down a bit.
I'll put tractor some tractor engine designs from the 60's on the table as lasting longer than some of the aluminum throw away junk that we are seeing now..... the very fact that these engines have survived in good running order with virtually no maintenance in some cases.. for? 37-47 years is a testament to their design..
Soundguy
   / "Parent Bore" vs. sleeved engines #13
I am sorry soundguy I wrote my post badly. I meant to say if you are talking about engines in general then car engines and pickup engines in the 60s and 70s were considered to be on the verge of worn out at 100,000 miles.
How would you compare mileage or hours as may be the case on a tractor engine versus car engine. Do you have any kind of idea what would be considered a risky amount of hours on a tractor engine where you would be figureing the cost of rebuilding it into the price if you were buying it ?
   / "Parent Bore" vs. sleeved engines #14
Actually.. that in and of itself makes a big difference.. IE.. rpm range. mostly old tractors are low rpm.. low compression engines..
That low rpm saves them a bit of wear and tear.
Hours are generally only a flimsy guideline untill you get real high.... Actual condition of a tractor makes a better determination of fittness. Things like ' how rounded is the clutch pedal'... state of repair.. maintenance.. etc..
In general though.. I pretty much considder anything under 1000 hours as 'break in'.. and for cut.. would expect 4000 hours of use out of an engine... In larger diesels.. 6-8 is a good lifespan before rebuild. I've seen well maintained diesels in the 10k and 12k range that were just starting to get tired..
Soundguy
   / "Parent Bore" vs. sleeved engines #15
No matter how you look at it car engines and tractor engines are different in design. We have ag tractor engines reaching into the 15,000 hour to 18,000 hour range with good oil and maintence. This would equate to over 500,000 miles if, I say if a tractor engine ran at 1/4 throttle and 1/4 load!!!! So multiply that times four for an accurate comparison! Just think of over two million miles on your car!!!!!!! We have tractors in our area that are pushing the 40,000 hour mark with normal rebuilding of the components.
   / "Parent Bore" vs. sleeved engines #16
Reminds me of a 80 or 81 mack tractor ( semi ) that our company sold a few years back. We bought it used from a milk hauler.. had nearly 800K on it.. they gave us the service logs for it and it never had any work on it other than routine service. We dropped the mains and they were virtually at new tolerance levels... left the m like they were.
We ran it for years and got it to nearly 2 million when we sold it. All we ever did to it was a new air compressor, and the rear, rear diffy was replaced.. aside from regualr maintenance items...
That thing just always wanted to go.
When we sold her we replaced her with a western star that.. while more powerfull.. just didn't have the working spirt of that old mack. Sure.. at 2 mil miles she poured some black smoke out when hauling 80,000 pounds of heavy equipment on a flatbed... but she always started right up and newver broke down on us... They just don't make passanger auto engines like that...
Soundguy
   / "Parent Bore" vs. sleeved engines #17
Whith ford tractors just bore em out bigger and put sleeves in "Turn a ford into a cummins" LOL
But other brands like CAT or DETROIT i've wasted a lot of money rebuilding a dead duck , Recently $9'800 dollars rebuilding a detroit 671 turbo and still a peice of s@#t , you have to look at what it's going to cost , I usually do all our own work but i am not familiar with detroit "two cycle system" so i payed a very reputable shop and still got a bill of this size , I could have rebuilt a cummins or perkins my self for half of this and knew what i was getting or like my initial thought "Rip it out and put a cummins" But i got talked out of this .
I realy don't think sleeved or sleeveless makes a better engine ,I'm an absolute lover of every thing ford( diesel) and i've had good results with CAT 3208's but a sleeved engine you can rebuild yourself and labour is the killer .
Cummins build engine and thats all they do ?
Motor manufacturers , Theres no rule i've rebuilt 3000 hr JD's and i have Cummins 855's with 9'000hours and never had mains and don't burn a drop of oil ?
   / "Parent Bore" vs. sleeved engines #18
I have zero experience with tractor engines, but a lot of years with stationary diesels in gensets. Cat 398 and 399 were absolutely bulletproof. We had a 399 that ran a whole year with 23 hours down time. That was for oil and filter changes, and an injector or two. These engines were of the wet sleeve type and could be rebuilt nicely after some spectacular failures. Actual block repairs were very rare and if needed, very costly as it had to go out for those repairs. Also had Fairbanks Morse opposed piston, that was wet sleeved and again same types of plus and minuses. As stated, to determine which type is better would depend on wants and actual application,,IMHO
2018 John Deere 645FD Flex Draper Head (A50657)
2018 John Deere...
2014 Chevrolet Tahoe SUV (A49461)
2014 Chevrolet...
Flat Deck Trailer (A50322)
Flat Deck Trailer...
1275 (A50490)
1275 (A50490)
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50774)
WE DO NOT...
2015 DODGE RAM...
