Parting out - Deutz Allis 5230 Tractor
   / Parting out - Deutz Allis 5230 Tractor #21
This is a 2wd tractor. As you have discovered, 4wd front axle parts are now almost impossible to come by. I bought this parts tractor specifically to pull the 2wd front end off and install on my 4wd tractor so I would still have a tractor to use while looking for parts needed to eventually rebuild my 4wd front axle.
After I tore down the 4wd front axle, I found that all it needed was bearings and seals. All my castings and CV joints were still in good shape, so I never used this 2wd front end.
If you are interested in the 2wd front end let me know. You can always sell it after you repair your 4wd front axle.
My left front 4wd gear box internals are gone. I can buy the bearings, however, the cv joint is in pieces and the king pin bearing is gone. Where you ever able to find axle parts for the 4wd?
I might be interested in the 2wd if I cannot find the 4wd parts.
How much do you want for the 2 wd front end? And where is it as freight might be an inhibitor.
   / Parting out - Deutz Allis 5230 Tractor #22
Hi, Do you have the governor off the engine? Rich @ wildwind3962yahoo.com
   / Parting out - Deutz Allis 5230 Tractor #23
I came across your post and was wondering if you still had any sheet metal parts left? I have a 5230 I think the parts are the same. thanks randy
I do have the sheet metal. I will send you a private message with contact information.
   / Parting out - Deutz Allis 5230 Tractor #25
thank you, will you let me know what you have and your asking price. randy
   / Parting out - Deutz Allis 5230 Tractor #26
Looking for 4wd front axle left side gear case for mf 1035 or deutz allis 5230 casting # 60718
All I have is this 2wd parts tractor. I still have the complete 2wd front end you can bolt on and make your tractor usable while searching for 4wd parts.
Will barter remaining parts for 55-64 Ford tractor parts.
   / Parting out - Deutz Allis 5230 Tractor #29
Hello Sir,
I have been searching around for the 4 wheel drive front end to the 5230 and ran across your thread.
Wondering if you still have the 2 wheel drive front end? If so, do you have a price in mind?
Very interested if so...
Please advise either way and I will continue on with my search.
Thanks for your time.
Bob in Maine
Bob in Maine,
I do still have the 2wd front end, sheetmetal and fenders. I was just thinking the other day that I should list what I have left of this tractor on ebay.
Located near Greenville, SC - 29644 zipcode.
2016 Ford F-450 4x4 Ambulance, VIN # 1FDUF4HT3GEC45874 (A54865)
2016 Ford F-450...
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
2011 SHOP BUILT FLARE STACK (A53843)
2011 SHOP BUILT...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A55218)
2021 NEW HOLLAND...
UNUSED WOLVERINE PT-16-01C 3P QUICK ATTACH (A54757)
UNUSED WOLVERINE...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A54757)
UNUSED WOLVERINE...
