Partner 5000 and 5000 Plus
   / Partner 5000 and 5000 Plus #11
To see new post just click this at top Show unread posts since last visit.
or this at bottom View the most recent posts on the forum. All pretty simple.
Not much posting in Partner sub forum area because only us older people know of them.
Ok thanks that will help,and who you calling old?:laughing::laughing::laughing:
Chainsawrepair
Administrator
Hotsaw
Friends an Learning is what this site is about
Re: Partner 5000 or 500 chain brake/ side cover
ォ Reply #3 on: Today at 04:47:30 pm サQuoteThats the best way is to buy parts saws for parts. Lot cheaper in long run.
To free up a bad crank bearing. I would split case remove both bearings. Put 2 new bearings in $10 total and 2 new seals and reused crank gasket if you can keep from ripping it. Why chance ruining the saw totally with a iffy $5 crank bearing. Report to moderator Logged
Hope we all can learn from each other. Thanks for sharing your info and time with us.
Jeff
3 cube
ォ Reply #4 on: Today at 05:30:46 pm サQuoteModifyRemoveWell there is a reason I asked that.
First off I did just a moment ago buy a Partner 500 fo $40.00 it has a broken control handel but I have spare pats.I may have listed the saws that I was about to look at in the wrong order.
Now as for the crank bering:
I am prettty handy but not very confidant.I have changed jugs and Pistons, clutchs and stuff but I have NEVER been inside a split case,,, the fact is I have never opened a case. I was reading in my new service manual about spliting the case.It seems that to remove the flywheel you need some special tool.We used to use flywheel pullers in High School but I do not even have one of those .Also I am not sure if I need to compleatly remove the crank from the saw if so is'nt there somthing on the opposite side as well? a oil pump gear sounds about right ? But I am not sure. Then it said the case must be heated up to accept the new seals? Not to sound like a nooby but This kind of scares me some. I have done a lot more thn some people but I am not on par with you guys either. So that is why I was wondering if I could free up the crank bering.I agree withassement though, that I wanted to install new bering and seals as well she would be almost as good as new then. I wonder if there is somebody on this site close to me in Maine that would stand over me while I do that?
2011 DOOSAN ALL TERRAIN FORKLIFT (A52576)
2011 DOOSAN ALL...
2021 Fendt 1050 Vario Tractor (A53342)
2021 Fendt 1050...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
Informational Lot - Financing (A53472)
Informational Lot...
36'' Mini Excavator Bucket (A51573)
36'' Mini...
2019 Ford F-450 Utility Truck, VIN # 1FT8W4DT8KEF27612 (A51572)
2019 Ford F-450...
